A
Anonymous Posted on Aug 19, 2014
How to set the scan settings - PIXMA Canon Office Equipment & Supplies
ARUN BORA
Level 2:
Champion:
  • Expert 241 Answers
  • Posted on Aug 19, 2014
ARUN BORA
Expert
Level 2:
Champion:
Answers
241
Questions
5
Helped
87288
Points
457
Open mp nevigator
then select scan/import button and click photos/document pallate
then select (tick) use scanner driver and and open scanner driver
then in advanced mode there is settings for various parameters like DPI, PHOTO, and douments etc place ur documents and preview first select appropriate area and click scan
How to scan more than 1 page at a time
ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. Open HP Solution Center with one of the following methods:
  1. Click Start , click All Programs , click the HP folder, and then click HP Solution Center
  • Double-click the HP Solution Center icon on your desktop. A "Scanning from..." screen displays to prompt for scan settings. If this settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. Click Scan Settings , and then click the appropriate option from the popup menu: Scan Picture Settings or Scan Document Settings .
    3. Select the check box, Prompt for settings at the time of scan , and then click OK .
    4. Click Home , and then start the scan again.On the "Scanning from..." screen, click the appropriate option under "Scan Shortcuts" on the left. Each shortcut has a default group of settings that display when you click it.
  • Click Change Settings , and then read through the drop-down menu choices for all of the settings for the shortcut, adjusting any settings as necessary. Also click the Advanced Picture Settings button and the Save to file Save Options button to view your choices and make any changes. Important : HP Solution Center versions and options vary, depending on your printer. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  • Click Scan . The preview screen might display, if you selected the option to show a preview. Use the options on the preview screen to make any desired adjustments before you finish the scan.
  • After the scan completes, it goes to the destination that you specified in the settings.
  • Scan Button: HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. Important: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want. NOTE: The steps to set up the scan button on your printer can vary depending on your printer model, and the version of software that is installed. For specific instructions, click the Help button on the home screen or settings screens in HP Solution Center.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Scan settings
    Scan settings are set in the scanning software. Most scanners come with a simple option (i.e. fully automatic) and an Expert option (where you can change the settiings as you wish.
    What make of scanner is it and how are you initiating the scan?
    1helpful
    Scan image is not its actual size
    Check the following. Open your HP solution centre, settings,scan settings, Scan picture settings or scan document settings. on the right hand side youll get scan pic setting again and check the setting in that box. Check also settings print settings, printer settings, check here for print or scale size
    2answers
    How do I scan a document into a pdf and send by email
    hi,
    HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.hp.com/printer/prob676ijt65/solution
    astrtr21
    2helpful
    Bizhub C250 How to set scan to multi page TIFF for everyone. How to scan front and back of documents Thanks
    To set scan default:
    Select Scan Mode
    Press Scan Settings
    Press File Type
    Press TIFF
    Press Multipage
    Press Ok
    Press Utility/Counter
    Press User Setting
    Press Initial Setting
    Press Current Setting
    Press Ok
    Press Reset
    This will only affect address book destinations. Program destinations specify within their settings the file type.
    To scan front and back:
    Select Scan Mode
    Select Destination (must be done 1st!)
    Press Scan Settings
    Press Simplex Duplex
    Press 2 Sided
    Press Ok
    Scan to computer
    Several ways to control your scanner:
    From this HP link
    Changing scan settings in HP Director
    Scan settings include resolution, output type, and file type. These settings can be changed using HP Director.
    1. Open HP Director, if it is not already open:
      • Windows 2000: Click Start , click Programs , point to HP , and then click HP Director .
      • Windows XP: Click Start , click All Programs , point to HP , and then click HP Director .
    2. In the Select Device list, select your product, if it is not already selected.
    3. Click Settings , and then point to Scan Settings & Preferences .
    4. Click the scan setting menu that corresponds to the type of file you are scanning.
      • Scan picture settings : Designed for scanning pictures, including any type of non-text image, such as a drawing, logo, or photograph
      • Scan document settings : Designed for scanning documents
      • Scan preferences : Control scanning preferences, such as automatically straightening crooked images
      • Button settings and Scan to... setup : Control the defaults for the scanner buttons on the control panel of the product
      After selecting the appropriate menu, the corresponding window opens.
    5. Change settings as appropriate, and then click OK . The scan setting window closes.
    6. Click Scan Picture or Scan Document HP Director to scan with the changed settings.
    From this HP link
    Using the Advanced Scanning Features of the HP Solution Center Softwaretoo large to paste - just follow the link above :)
    Here the main site for the scanner - click here
    SCANNER SAYING NO USER ID
    This means that you have not set up any users in the address book in the printer.
    Copy is simple, it will scan the document and print out a copy of the scanned image.
    Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
    The material below is how to set up the scanner settings of the printer.
    Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
    When you install the Dell software, the Printer Settings Utility is automatically installed.
    For information about installing the software, see "Installing Software in Windows".
    To open the Printer Settings Utility:
    1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
    The Printer Settings Utility window opens.
    1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
    The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
    2answers
    Won't scan legal documents properly
    Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
    Scanner will not save to computer
    By default, the HP all-in-one sends all scans to the HP Photo & Imaging Gallery for you to preview. Suppose that you want to scan your photos directly to email instead. To do this you will need to modify the destination assigned to the front panel scan button. Here is how to do it:
    1. If you have not already done so, open the HP Director and click Settings , point to Scan Settings & Preferences , and click Scan to… Setup . The Button Settings dialog box appears, with the Destination List tab on top. The HP all-in-one automatically inventories your computer and lists all the possible scan destinations for you in the Available Scan Destinations list.
    2. Using our example of scanning directly to email, select the Email destination in the Front Panel Destination List and click the Move arrow to move it to the top of the listing.
    3. Click OK to save the new destination setting and close the dialog box. All of the scans you do using the HP all-in-one front panel buttons will now be sent directly to your email program, instead of to the HP Photo & Imaging Gallery.
    4. Click Scan Picture or Scan Document in the HP Director to scan using your new settings, or click a Scan button on the HP all-in-one front panel.
    also
    Setting a default scan profile Use the following steps to apply a scan profile to all future scans.
    1. If you have not already done so, open the HP Director and click Settings , and click Scan Settings and Preferences .
    2. Click one of the following, depending on the type of scan profile:
      • Scan Picture Settings
      • Scan Document Settings
      • Button Settings The corresponding dialog box appears. If you chose Scan Picture Settings or Scan Document Settings , the Scan Settings tab is on top. If you chose Button Settings , the Scan Button tab is on top. All of these tabs have the setting you need, Apply Scan Profile .
    3. On the Scan Settings or Scan Button tab, click Apply Scan Profile and select the scan profile that you want.
    4. Click OK . The scan profile that you selected will apply to all future scans for the scan type that you selected.
    2answers
    HP Officejet Pro L7580
    scotti444 ,
    hi! try this solution for your problem.tnx
    Follow these steps to correct the problem:
    1. Open the HP Director/Solution Center software.
    2. Click Settings , click Scan Settings and Preferences , and then click Scan To....Setup . The Button Settings window will appear.
    3. The Destination List tab should be visible. The software will scan the computer and determine what scan capable programs are installed on the computer. These will be listed on the left side.
    4. Select a program you wish to scan to and then click Add to move it to the right side. Programs listed on the right will be available as scanning destinations when pressing the Scan button.
      Figure 1: Destination tab of the Button Settings
    5. On the Scan To Button tab, you may also specify what type of scan you wish to launch from the front panel and establish a default scan resolution and color depth setting.
    6. Click OK to save the changes and exit the setting.
    Causes:
    >This error message occurs if the Scan To settings have never been set.
    hope this can help you resolved your problem
    regards,
    coffeebeans
    old marine
    old marine
    ZJ Limited
    ZJ Limited
