20 Most Recent Canon PIXMA MP830 All-In-One InkJet Printer Questions & Answers
ERROR CODE 6A00
Effective Solutions to Troubleshoot Canon Printer Error Code 6A00: Cartridge faults are not always easy to deal with. Solution 1: Check Print Head Carriage
  • Make sure whether the printhead carriage is moving back and forth properly or not.
Solution 2: Check the Purge Unit
  • If you have just moved the printhead assembly, the purge unit error will still be there.
Solution 3: Reseat the Ink Pads
  • Press down the ink pads down in the purge unit.
To know more: Canon Printer Error Code 6A00
2/4/2022 5:03:38 AM • Canon PIXMA... • Answered on Feb 04, 2022
4answers
Canon MP830 Service Error 6000
Canon PIXMA MP830 all-in-one Inkjet Printer
Error code 5C10 on computor screen and on the printer it says 6A00
10/6/2021 3:26:32 PM • Canon PIXMA... • Answered on Oct 06, 2021
4answers
Error: The type of Printhead is incorrect, Install the correct printhead.
Ok i know this is kinda old, but i found a solution.
First to those people to state I found a solution from hp, cannon etc etc and not give out the direct link, or instructions, then whats the point fing posting????
This error happens when you install an oem cartridge onto your system. Or havent used it in a while, so the machine is somehow misfigured.
This solution is for canon mp800, simply switch off printer. HOLD stop/reset and press and HOLD on/off button. release stop/reset. Now press stop.reset twice. then release on/off button, press stop/reset 4 times, wait 20 seconds, press on/off button twice.
switch machine back on and the printer should find the cartridges.
This method maybe the same for your mp*** if not google RESET CANON PRINTER MP*** and you'll find the correct buttons to press.
here's a printer on reseting a bunch of canon printers http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
good luck.. and FU canon for adding you scamming chips into cartridges.
7/22/2021 3:43:37 AM • Canon PIXMA... • Answered on Jul 22, 2021
2answers
First start up of the day error code u140
said error 6A00 CODE
9/25/2019 10:46:39 AM • Canon PIXMA... • Answered on Sep 25, 2019
Error code 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
All The Best: Pineworks
5/16/2019 9:20:41 AM • Canon PIXMA... • Answered on May 16, 2019
My Canon MP520 display screen is alight but blank
I had this problem too and I discovered that there is a sort of switch in the display lid that malfunctions. It is probably there to switch off the display if you close the lid while the printer is on.
The solution is to open the lid just enough to reach the on/off switch and turn the printer on. If you now open the lid fully the display is up and running like you were used to.
2/12/2019 10:43:25 AM • Canon PIXMA... • Answered on Feb 12, 2019
6answers
'unable to save file. the system cannot find the path specified'
Had this same problem and just fixed it. You need to actually change the button settings in Navigator. Open MP navigator and choose One-Click, then click Button Settings. You can choose a new save destination from here. Even though you are using the software instead of the button on the device, it works.
1/9/2019 10:13:17 PM • Canon PIXMA... • Answered on Jan 09, 2019
4answers
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
9/27/2018 9:55:46 PM • Canon PIXMA... • Answered on Sep 27, 2018
How to reset waste counter ink canon pixma E500?
Plug the cable, push stop/reset then push power button. Still Hold power button, then press stop/reset 5 times then release. You now enter in service mode. Then run Canon service tool v.3.400
9/20/2018 5:48:43 AM • Canon PIXMA... • Answered on Sep 20, 2018
What does canon pixma mp830 error code 6000 mean?
That is a line feed error (6000) It also should be flashing 3 times for this error on the on/off button.
This could be
1. Timing sensor unit QM2-2683
2. Timing **** disk film QC1-6229
3. Feed roller ***'y QL2-0925
4. Platten unit QM2-2923
5. Logic board ***'y QM2-3078
6. Paper feed motor QK1-1502
3/25/2018 7:30:55 PM • Canon PIXMA... • Answered on Mar 25, 2018
Canon MP830 will not print. Makes all the
Hi . That problem is the print head. Is defective. Buy a continuous ink system printer. Is more efficient
2/11/2018 2:01:17 AM • Canon PIXMA... • Answered on Feb 11, 2018
Hi, please help me solve my problem.
Did it finish maintenance before you reboot?
12/15/2017 7:36:17 AM • Canon PIXMA... • Answered on Dec 15, 2017
Why is my Canon Pixma 830 Printer beeping once upon start up, the screen lights for a second then the printer shuts off?
Either a power supply fault or there is a fault in the main circuit board. You may find a replacement power unit (they are held in by two clips ) at an electronics recycler or auction site like e-bay, but the main board is not an available part.
12/11/2017 8:46:21 PM • Canon PIXMA... • Answered on Dec 11, 2017
Canon MP830 wont scan.
hi Jackelle21. i have had a look around the internet and all i can find out from going into forums is that the problem might be because you need to download what they are calling (mp navigator) so not sure if this is what you have to do.but if you go to this link you will see download sites to where you can get it. mp navigator download Google Search or this one. Canon MP Navigator EX
11/27/2017 6:47:01 PM • Canon PIXMA... • Answered on Nov 27, 2017
Alternating dark and light bands
The most common cause of this is a failure in one of four earth circuit in the print head. It is not repairable
11/21/2017 11:13:02 PM • Canon PIXMA... • Answered on Nov 21, 2017
Mp380 printer will not turn on
hi deborah. see if this link helps you find out why it will not turn on. Mp 380 printer will not turn on Google Search
11/3/2017 4:34:33 PM • Canon PIXMA... • Answered on Nov 03, 2017
Downloading software
MAC OSX would not download, rather it was downloading progressively slower and slower. If I waited for it it would have taken hours if at all. That was using Safari, after I downloaded FOXFIRE browser it only took a couple of minutes.
10/9/2017 11:53:09 AM • Canon PIXMA... • Answered on Oct 09, 2017
Message bank
Look through your fax machine instructions,. There should be some there regarding how many rings before pickup. Or maybe the unit does not have that feature and is designed to have its own separate line for faxes.
9/21/2017 9:28:46 PM • Canon PIXMA... • Answered on Sep 21, 2017
Canon PIXMA MP830 All-In-One InkJet Printer Logo
1,992 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
get canon pixma mp830 printer print
  • Office Equipment & Supplies
