20 Most Recent Samsung CLX 3160fn All-In-One Printer Questions & Answers
Take aout waste toner tank (vertical handle left of cyan toner cartridge)
remove waste toner. Make shure that transparent windows are clean (light barrier). Replace aund resart printer
Samsung CLX... | Answered on Nov 07, 2018
Under warranty ring samsung to confirm, the error relates to comunication with the ram chip, probally not seated, but I think you might find in has a "in house" warranty which means they will come to you.
Samsung CLX... | Answered on Apr 25, 2018
open the front cover and empty the waist toner then try again.
Samsung CLX... | Answered on Feb 09, 2018
Dear
There is a problem in the fusser unit.Turn the power switch off and on. If the problem persists, call for service engineer.
Thanks.
Samsung CLX... | Answered on Oct 21, 2017
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Samsung CLX... | Answered on Feb 01, 2017
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Samsung CLX... | Answered on Jan 17, 2017
Yes it would appear your printer have been damaged due to the storm. The reason your fax is "off hook" the that the photocoupler that protects the printer from surges on the telephoone line has "blown". THe printing problem is due the the surge that damaged your computer also passed down the USB cable to the Printer and has "fried" that part of the circuitry
It maybe possible to repair it but you will need to take it to a Samsung Repair centre or Authorised Repair centre
Sorry for the bad news but hope it helped
Samsung CLX... | Answered on Nov 25, 2016
unlocked the scanner, but now I can't PRINT! HELP ME!!!
Samsung CLX... | Answered on Mar 29, 2016
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Samsung CLX... | Answered on Dec 01, 2015
you may have to set up the email server address.ie the SMTP Server address in the file sharing settings. you cant scan to email without this. you need the email provider address and you may need to set up your admin email. you can use your own for this. if you can scan to a folder you can always forward as email from your docs folder if you have a problem.
Samsung CLX... | Answered on Oct 19, 2015
check black developer unit
Samsung CLX... | Answered on Oct 02, 2015
Ok to clean glass get tough and do not wreck the machine, sounds bad but damage could occure if your not careful but forceful.
1)down load any faxes not printed or sent to your computer
2)turn unit off with power button
3)inside of paper exit opening in the upper left hand side push green slide lever towards the back of the machine,,this locks the scanner carage(you can also see the green lock through the scanner glass to the left of the scanning carage as you move the lock). I did this not to disturbe the scanning carage while cleaning the glass.
4)the lid to the scanning bed has to be removed by lifting the complete tray to it's limit and unplugging the data cable,,it is in the middle between the hinges(pinch the cable connector plug locks on both sides and pull out the connector. To release the rectangular hinges lift and tilt the complete unit further back toward the rear of the printer/fax machine. It should lift out and REMEMBER that rear tilt when replacing the fax/printer feed unit as the hinges don't just slide back in to the respective holes.
5)there are two screws near where the hing holes are on eather side of the scanner cover they must be removed.
6)NOW this is the tricky part with only your hands no tools,,,with a large amout of force lift the back corner of the scanner cover(this does not seem possable but lifting at the side of the machine the cover does have a slight lip to lift with and it makes tearable sounds of distruction BUT IF you lift each side near the rear upward for about 1/2inch at a time(side to side)"2 INCHES ONLY" total the cover will give enough room to CAREFULLY reach your hand under the scanner cover with a damp rag to clean the glass and dry with a lint free rag(micro fiber rags work). I used no cleaners at all but lint free is the ticket. DO REALIZE THE TRAY ONLY LIFTS UP ABOUT 2 INCHES from the rear and it should stay up at the 2 inch hight. The removal of the scanning cover would mean more dissasembly of the unit and I saw no need to go that far.
6)NOW to replace the scanner cover (hopefully you were carefull enough not to crack or break the glass as lifting unevenly or pulling upward more than 2 inches could be the end to your scanner. The trick to get the cover back down with the registration tabs into thier respective holes,,it helps to pull outward on the sides of the plastic body where the tabs have to drop down into,,the large taps at the rear are a little less co-operative but with a bit more force the back body will seperate slightly and the read pins fall into place.
7)put the screws back in, then the scanner cover hinges first and snap the data cable into place,,Don't forget to slide the scanner lock (green tap)towards you to unlock the scanning tray.
Good Luck, it sounds difficult and it might be but it can be done without damage. I'm sure a true service repair man would not like the method but my machine is near it's final useful days.
Samsung CLX... | Answered on May 28, 2015
the username is
Admin
Password is
sec00000
Samsung CLX... | Answered on Jan 20, 2015
Samsung CLX 3160fn All-In-One Printer Logo
565 questions posted
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
clean glass samsung clx 3160fn
  • Office Equipment & Supplies
