20 Most Recent Canon PIXMA MP810 All-In-One InkJet Printer Questions & Answers
Changing the print size on a Canon MP 810
Using Gimp , I imagine you are using Linux not Windows. Download the latest driver from the Canon website and make sure its the correct one for Linux. I am not aware of any settings within the 810 that can be changed as print size is governed by the driver and not the printer. Make sure you UNINSTALL the old driver and don't just DELETE it .Good luck
9/6/2016 7:04:13 AM • Canon PIXMA ... • Answered on Sep 06, 2016
I have been given a Canon MP810 but it is only printing in a very small text on a small part of the A4 page. How do I change this?
While clicking print. There is a option for resolution. You can change there
9/5/2016 7:56:01 AM • Canon PIXMA ... • Answered on Sep 05, 2016
3answers
Error code 6000
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing disk film or the printer's logic board.
9/21/2015 6:55:35 PM • Canon PIXMA ... • Answered on Sep 21, 2015
How do ] f[nd the scanner lock switch to unlock it
Do you mean the mechanical lock switch on the side of a scanner that stops the mechanism from moving while being transported?
3/2/2015 1:13:33 AM • Canon PIXMA ... • Answered on Mar 02, 2015
My canon MP810 all-in-one printer, i've cleaned
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position. Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center.
9/17/2014 8:58:06 AM • Canon PIXMA ... • Answered on Sep 17, 2014
Change language to English
1 - Press Home button, wait 5secs. and select the tool icon 2 - Press the right button and select what looks like 2 slides with small tabs 3 - Press the down button 4 times (5 times if you have blutooth) and press OK 4 - press up/down and select the language you want and press OK
8/7/2014 5:18:21 PM • Canon PIXMA ... • Answered on Aug 07, 2014
How do I change the language
1 - Press home button and after 5secs select the tools symbol and press OK 2 - Press Right(Forward button and select wht looks like two slides with small tabs 3 - Press down button four times (five times if you've bluetooth) and press OK 4 - Press up/down to select the language and press OK
8/7/2014 12:27:07 PM • Canon PIXMA ... • Answered on Aug 07, 2014
0answers
0answers
3answers
Cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
11/8/2013 2:30:34 AM • Canon PIXMA ... • Answered on Nov 08, 2013
My printer isn't producing any ink?
The manual says:Follow the directions given in the Easy Setup Instructions to install the Print Head.If the Print Head is already installed, remove the Print Head once and then reinstall it.If the error is not resolved, the Print Head may be damaged. Contact your Canon Service representative.take care putting the head in as discribed in the setup description.I'll think it over if there could me more
10/27/2013 2:56:07 PM • Canon PIXMA ... • Answered on Oct 27, 2013
3answers
Chinese information
Had same problem, don't know why but here's how to fix it...
(1) Press the HOME button. Wait for about 5 seconds, select [pliers & screwdriver icon]i_settings4.jpg, and then press the OK button.
(2) Press the r_mark_s5.jpg[right cursor] button to select [sliders & levels icon]i_devicesettings6.jpg, then press the OK button.
(3) Press the [down cursor]d_mark_s7.jpg button four times, then press the OK button.
If the Bluetooth unit is connected to the machine, press the {down cursor]d_mark_s8.jpg button five times, and then press the OK button.
(4) Press the t_mark_sv9.jpg[up cursor] or [down cursor]d_mark_sw10.jpg button to select the language you want to be displayed, then press the OK button.
8/23/2013 6:23:11 AM • Canon PIXMA ... • Answered on Aug 23, 2013
Printer driver for windows 8
From the Canon support site: "There is no driver for the OS Version you selected. The driver may be included in your OS or you may not need a driver."
2/27/2013 8:24:42 PM • Canon PIXMA ... • Answered on Feb 27, 2013
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
260 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
changing print size canon mp 810
  • Office Equipment & Supplies
