20 Most Recent Canon PIXMA iP4600 Color InkJet Photo Printer Questions & Answers
You will need to open the ink cartridge door and let the print carriage go to the middle. Then, remove al ink cartridges and lift the latch to remove the printhead. This video shows another Canon printer, but same concept:
Canon PIXMA... | Answered on Jan 30, 2019
this is how to do it use xp
http://www.mediafire.com/?dbi16o3ovel1iyk
download the v3400 for free in link above it is 9,5mb ( there is a other file dont use it only the service mode tool v3400 )
follow this instructions and you will be fine
http://www.2manuals.com/product_info.php?products_id=1445
- power OFF the printer bu Power button. Dont disconnect power cable
- connect the printer by USB cable to the PC.
- press and hold Resume button (red triangle in the red circle) and press Power button
- hold both buttons until power on indicator will light then release resume button (dont release Power button) and press Resume button 5 times
- release all buttons - the printer will blink few times with green light and will then light green constantly. You have put the printer in Service Mode now and you can now run the Service Tool. (If the printer is still blinking by green - you have some other errors in printer and you have to fix them first, because the Service Tool will not work if the printer is not put in service mode - green light is constant)
4. Run the Servicetools V3400.exe program.
5. Select the connected USB port number from USB PORT
6. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
7. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Print EEPROM information to confirm that the value is properly set to the EEPROM
Canon PIXMA... | Answered on Mar 27, 2018
The Canon service info is:
B200/P10 - Orange and green light blinking 10 times Description: A service error has occurred. Resolution: 1. Turn off the printer. 2. Disconnect the power cable. 3. Open the printer cover. 4. Check for any orange protective tape or white polystyrene and remove if necessary. 5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary. 6. Close the cover. 7. Reconnect and turn on. If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
The error code is usually given for a foreign object present in the print head carriage path, so check at both ends for a crumpled up wedge of paper. If nothing is found, it is most likely that your print head has an over-heating problem and is dying
Canon PIXMA... | Answered on Dec 11, 2017
Many times the switch that lets the printer know it's out of paper is stuck in position, or dust has clogged it. If you can blow the small bits of paper or dust out you can get it going again. I use a can of compressed air to clean my printer about once a month to stop this from happening. It is a common problem.
Canon PIXMA... | Answered on Jul 23, 2017
issue with registry uninstall the driver remove the entries from registry . reboot the system try again
skype id :johnwalker800969
Canon PIXMA... | Answered on Sep 12, 2016
Reset canon waste ink ip4600 problem
Reset Printer Canon ink absorber
Hi there they say the new printers same as you got cant be reset it go to be the shop to do this but you can try this, but pleas can you come back let us know if it worked so other can use this trick, Thanks
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Colour
Canon PIXMA... | Answered on Jun 08, 2016
pl. check the paper sensing sensor, paper pickup roller & replace
Canon PIXMA... | Answered on Nov 04, 2015
check the paper jam, at the feeding area
Canon PIXMA... | Answered on Oct 31, 2015
Canon PIXMA iP4600 Color InkJet Photo Printer Logo
313 questions posted
Clive
Clive
old marine
old marine
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
canon ip3680 waste ink absorber
  • Office Equipment & Supplies
