20 Most Recent
Canon PIXMA MP610 InkJet Printer Questions & Answers
My canon MP610 printer is not responding after replacing ink
Many other machine users who use Canon's wireless printer for work-related or special printing work frequently find that their printer does not respond at any point in time. If you feel the Canon Printer Not Responding to issues on a regular basis, it is best to ask the aid of expert Canon Printer Repair Technicians or Complete Solution BLOG, as they will be able to solve the problem quickly. The key reason behind Canon Printer Not Answering Error is a lack of information between your PC and your printer. If this is the
Canon Printer Not Responding Mac, there are a few steps below that could help you solve the problem.
Reasons that Makes [Canon Printer Not Responding]:-
>>The printer driver is configured with an improper port.
>>An incorrect access point was selected during the initial setup.
>>3rd party firewall or antivirus software is interfering with the printer software.
>>USB problem that refuses to establish contact under Windows (if a wired connection is used)
Complete Blog:
Thanks for reading..!
I have a Canon Pixma MP610 which won't turn on
Good Day Paula!
You can reset the waste ink tank counter by a reset procedure. Bu this doesn't actually empty the waste ink tank itself and will allow you to
continue printing.
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
Greetings, I have a Canon Pixma M610 and this
Try removing all ink cartridges and printhead from the printer. Then, look inside the printer with a flashlight. Look into the right side of the printer and see if there is lots of ink gunk. Remove if any and try not to leave ink gunk on other printer parts. Turn printer off when removing ink gunk. Then after you are done cleaning, turn printer on and wait for it to command you to insert printhead. Do that and close cover. Then, insert cartridges when printer asks for them. Hope that helps. -Alex
303Electronics eBay Stores If you need further help, I’m available over the phone at
https://www.6ya.com/expert/alex_22751bbefa74c3d0
My scanner wont work because I have run out of
having no ink should not affect the running of a scannermake sure the scanner usb and power leads are securely seated
the drivers for the scanner might have been corrupted
you might have to uninstall the scanner restart your computer then reinstall your scanner
if your printer/scanner came with an installation disc the drivers could be on it
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow Question/exclamation ? ! mark or a red X this will mean you need to install a new driver for this device right click to update driver select properties again you will have the similiar options also have option to troubleshoot hope this helps you
MP610 ink absorber is full
Hi
Follow this link and you can solve the problem quickly
http://tricks-collections.com/reset-printer-canon-mp140-mp160-mp180-mp210-mp220-mp460-mp470-mp500-mp510-mp530-mp600-mp610-mp800-mp820-mp810-mp830-mp960-mp970/
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
How to make printer print
Take the print head on and gently tap the nozzles on a paper towel.If you see all the colors and black then unplug the printer after the printhead is out and the carriage travels to the end (capped0
Wait 30 minutes and re-install the head.
This hopefully will make the printer believe it is a fresh unit
