20 Most Recent Canon MX300 Office All-In-One Printer Questions & Answers
See this video for solution for error code 5100:
Canon MX300... | Answered on Feb 25, 2019
Try it works for most Canon
Hi you can try
Solution:
  1. Turn on the machine
  2. Press MENU
  3. Press SCAN COPY SCAN to enter service mode
  4. USE > to got to NVRAM ACCESS
  5. Set ABS-M LEVEL to 0
  6. Set ABS-P LEVEL to 0
  7. Press STOP to EXIT
All The Best: Pineworks
Canon MX300... | Answered on Mar 27, 2018
You might try a hard reset of printer along with uninstalling and reinstalling the software for the printer.
If nada, you might give Canon a call and ask their techies for their feedback on situation.
Canon MX300... | Answered on Jun 19, 2017
on the test print paper there should be a set of numbers there (prints automatically after align print head is done), these will need to be added into the prompt that comes up in screen after "set value" shows up, but unless a major rebuild has just been done to machine I find this is rarely needed to be done < I just select skip or done to exit that mode
Canon MX300... | Answered on Jan 20, 2016
If you are using any refilled catridges, remove it and try with original one. See if any dust is present or any pieces of paper left or struck inside. Make sure the catridges are not empty. Try it out.
If still it does not happen then call the technician to check the sensor part of the printer.
Canon MX300... | Answered on Apr 17, 2015
open the top and check for any loose paper jams.then use some
alcohol on a q-tip to clean all the rollers.
Canon MX300... | Answered on Mar 05, 2015
http://gdlp01.c-wss.com/gds/5/0300000425/01/mx300_qsg_us_v1.pdf
Canon MX300... | Answered on Feb 15, 2015
Have you downloaded or installed the full software for it? If so can you open the program first and initiate the scan from it?
Canon MX300... | Answered on Nov 17, 2014
sometime my printer does the same, print something and see how the black color is, if it is printing or it is the color ink that needs to replace also. i just keep printing until the ink get real light then i change them.
Canon MX300... | Answered on Jul 11, 2014
The fix for that error simply says to open the door by hand. If that doesn't fix the issue you need to contact a service center.
Canon MX300... | Answered on Jun 24, 2014
Canon MX300 Office All-In-One Printer Logo
645 questions posted
Clive
Clive
old marine
old marine
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
lost cd canon mx3oo
  • Office Equipment & Supplies
