20 Most Recent Canon PIXMA MX310 All-In-One Printer Questions & Answers
Drivers for pixma k10365 printer
need cannon k10365 drive
1/27/2024 7:20:01 AM • Canon PIXMA... • Answered on Jan 27, 2024
COL INK VOLUME UNKNOWN MESSAGE
Something that worked for me, I opened the Conon MX310. took out both cartridges, and for 10 seconds I held the Reset. put the cartridges back in, closed the lid, and again, for another 10 seconds held the reset. SLOW seconds. this reset, ink levels recognised,, and it's working as it should be.
Regards
Shane (AKA Reef_Lex)
5/16/2023 5:09:34 PM • Canon PIXMA... • Answered on May 16, 2023
How to scan document and save as pdf file
This software is completely free and you can easily scan and save as PDF : https://www.naps2.com/
10/17/2022 11:39:14 AM • Canon PIXMA... • Answered on Oct 17, 2022
4answers
Can' install the printer...on windows 7premium
Check the Canon WEB site for a Windows 7 printer driver. If there isn't one for Windows 7 then try the Vista printer driver. It may work but may not have all the functions. You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
8/8/2022 6:14:23 AM • Canon PIXMA... • Answered on Aug 08, 2022
2answers
How to I connect my Canon MX310 printer to my laptop?
Hello, you could opt for the USB connection. Plug one end of the cable into the USB port on your computer. After, plug in the power cable and turn on the printer.
7/15/2022 7:31:34 AM • Canon PIXMA... • Answered on Jul 15, 2022
My canon printer says it's
Go to Start/Control Panel/Printers and faxes. Right click on the Canon icon and click on Offline turn toggle it back to Online. Please rate this answer.
Cheers
Bob
2/2/2022 9:02:31 PM • Canon PIXMA... • Answered on Feb 02, 2022
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
12/1/2021 12:26:57 PM • Canon PIXMA... • Answered on Dec 01, 2021
Ink cartridges won't move to the left when
This is something I have seen on a number of occassions and it's always been the same issue. One of the ink cartridges has come unseated and has popped up out of its bay.
First of all make sure that the printer is not switched on. then open the lid. Get something thin and strong (rigid) - a 6inch steel ruler is ideal. Slide it in over the ink cartridges and then press down hard. Hopefully you will hear one of them click as it goes back into place. Turn the power back on and see if that has fixed it.
It generally does - but your's may be the one that doesn't.
11/21/2021 6:39:38 PM • Canon PIXMA... • Answered on Nov 21, 2021
How do i make copies darker canon pixma ?
Actually pretty easy to do and just in case someone never gets back to, Cannon does provide an online user manual.To darken copies: While in copy mode, press the menu button. Next, arrow over to "copy intensity", once there you should make sure that you\'re in manual mode, hit OK. This will bring up a darken/lighten mode and you can make adjustments from there to what you want. If your copier is starting to fade on it\'s initial copy setting, you also may be close to running out of ink if you haven\'t checked it in a while. Even though they shouldn\'t , if you don\'t used it that often, it can still dry out the connections. Hope this helps.
11/21/2021 5:54:24 PM • Canon PIXMA... • Answered on Nov 21, 2021
Black ink volume unknown
Problem is you refilled the cart and didn't reset it properly so it looks like a new cart, check your other carts and see if gears or holes are wrong.
11/17/2021 6:12:49 PM • Canon PIXMA... • Answered on Nov 17, 2021
3answers
Pixma mx328 check ink u051
The error usually came out after you refill ink on the black cartridge...there is no way you can make the printer work without resetting the ink cartridge..
Try to reset the printer using this procedure.. it will help.
1. turn off the printer..
2. press/hold the stop/reset button..and press/hold power button too..
3 while holding power button, release the stop/reset button..
4. then press the stop/reset button twice..
5. release power button..and wait until the power button lights a steady/still green and says "idle"...
6. open the cover...take out both catridges.. then turn off the printer.
7.put back the cover then turn on...
8. now put the catridges back.. and wait for some time to return to display menu... then try to print...
The printer may still prompt a "black ink volume unknown and color ink volume unknown" but don't worry that won't affect the operation of the printer. And you will able to use your printer, fax and scanner.
Do this every time you refill the ink of the cartridges.
If you find this solution helpful please vote on this on the YES below..thanks..
10/17/2021 6:47:03 PM • Canon PIXMA... • Answered on Oct 17, 2021
Canon mx310 error message U051
This will clear your printer from displaying common printer errors like U053, U051 and U052. The importance of the "reset the cartridge" procedure is to avoid the printer from detecting your cartridge as reused one. The steps below is recommended to do after refilling an ink cartridge.
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
Let me know if this works with you
Please rate this solution. Thanks
10/6/2021 4:02:45 PM • Canon PIXMA... • Answered on Oct 06, 2021
2answers
Fax interrupts phone calls
Go to the Canon Website downloads and drivers for the MX310
this page
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603
Download and use the update from 22 Aug 2008
This should solve your problem
9/23/2021 7:06:35 PM • Canon PIXMA... • Answered on Sep 23, 2021
Paper feeds halfway through and then 'Jams'
you have something stuck down in your paper path, if you feed a hard piece of plastic down the paper path manually and gently you will feel something is there, a very common problem
6/26/2021 8:07:06 AM • Canon PIXMA... • Answered on Jun 26, 2021
The fax on my printer keeps saying busy for all
just for 5 minutes for any receiving data or just shutdown and power up your fax machine....
5/18/2021 7:24:48 PM • Canon PIXMA... • Answered on May 18, 2021
2answers
2answers
Error code U140 check ink because I used a non-OEM cartidge
You need to buy the ink with the new chip installed, or buy a resetter. The only way to print now is with a new cartridge either Canon, or with a new chip.
1/22/2020 10:56:14 AM • Canon PIXMA... • Answered on Jan 22, 2020
10answers
I lost my cd to install canon MX310 software
Hi You don't need the CD, just go to this site: Driver Update and use their software to update your driver. Wish you best of luck Simon
12/4/2019 10:07:01 AM • Canon PIXMA... • Answered on Dec 04, 2019
3answers
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
12/4/2019 3:37:30 AM • Canon PIXMA... • Answered on Dec 04, 2019
4answers
Canon mx310 error code 6000
Error 6000 is a service call error, meaning that the printer needs to be taken into a canon authorized service facility for repair.
This is a line feed error, with the problem originating from the timing **** disk film or the printer's logic board.
8/19/2019 11:57:04 AM • Canon PIXMA... • Answered on Aug 19, 2019
Canon PIXMA MX310 All-In-One Printer Logo
2,559 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
canon pixma mx330 all in one printer
  • Office Equipment & Supplies
