Refrigerators Logo
R
Rebecca Buff Posted on Jun 22, 2019
I ordered a bypass plug for my water filter on my Frigidaire FFHS2611PFEA how do you put it on?
Eric Gundersen
Level 1:
Habit-Forming:
New Friend:
  • Contributor 20 Answers
  • Posted on Jun 24, 2019
Eric Gundersen
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
20
Questions
0
Helped
11121
Points
51
According to your model number a bypass plug wont work. Refer to owners manual. I dont think they make a bypass plug for your model.
I ordered a bypass plug for Frigidaire Refrigerator FFHS2611pfea water filter and I don' think it fits, or I don't know how to put it on
Some fixya user told me a website reliable-store it is very good.. I used it to repair my shredder it had some spark issue which wasn't easily fixed. you can go there and try
FGHS2866PF WATER FILTER BYPASS
That model does not come up. what is the question about bypass?
2answers
I would like to not use the filter.do i need a bypass plug to water filter on ffhb2740ps ?
Yes, you can get them on Amazon. for around $ 17.00 get the number off the filter before ordering one or two as the case maybe
I need a bypass filter for my Frigidaire refrigerator, Model FSC23F7DSB. I have an RO unit pumping water to the frige but hte filter in the refrigerator is doing two things. First it is contaminating the...
I looked for a bypass for your models but none listed . just remove the cartridge. this should work. you could also by pass the filter by connection the two lines lik they do on water softners. . valve or connector in back .. now a word to the wise . they do not recommend hooking the frig up to r. systems as the do not produce enough pressure to the main valve to shut if off ( sometimes ) thus causing a flood . if you do use 3/8 or better line size . this will help .. **** . hope this helped . mm
1helpful
Water filter removal
Lawrence, you will need to get a filter plug that replaces the filter, if you don't want to use the fridge filter element, otherwise, you will not be able to get ice and water from the dispenser.
I tried to look up the part you need, but the model number you provided appears to be missing some alpha or digits. I would suggest you contact KitchenAid or the retailer where you purchased it from, and ask them to order you the plug. Sometimes these fridges are shipped with the bypass plug installed and the new filter gets put in at installation by the delivery people, etc. If yours already had the filter installed, you'll have to buy a filter cap/plug in order to still get ice and water from the fridge.
Here's a link to a possible plug for your fridge:
http://store.appliancezone.com/servlet/-strse-56329/appliances-parts-repairs-replacements/Detail
Here's another one you can look at, just scroll down and you'll see the plugs mid-way down the page.
http://www.easyapplianceparts.com/appliancepartlist.aspx?Brand=KitchenAid&Appliance=Refrigerator&ModelNum=&Type=Filter%2C+Lint+-+Air+-+Water+-+Grease&MinSize=U&MaxSize=U&Electrical=U&Metal=U&Plastic=U&OneColor=U&PageSize=15&FirstPart=1
I hope you find this Very Helpful and best regards!
My water dispenser on the front stopped working...
Your filter might be clogged. Did your refrigerator come with a water filter bypass plug? If so, take the filter out and install the plug. If things start working again, you'll know it's the filter which you can easily replace.
Bypassing a filter
They do make a bypass for this which you can get at http://www3.sears.com/.  Will need to know the entire model # from the sticker on the inside of the fridge.  If you have trouble let me know.  I would the the model # also to help further.  Also, it may say something about it in the owners manual.  Let me what you find.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
