20 Most Recent
Frigidaire FFHB2740PP 26.7 cu. ft. French Door Refrigerator with SpillSafe Glass Shelves, Gallon Door Bins, Full-Width Drawer, Water Filter and External Ice/Water Dispenser: Pearl White Questions & Answers
My Frigidaire up right freezer is showing an error code "FF" and is beeping. What is the issue?
Hey friend, thanks for your inquiry!
Within your Frigidaire freezer the error code "FF" stands for freezer failure. I would perform a reset on your appliance which can be done by either unplugging the power cord or flipping the household circuit breaker. Once the freezer has come back on you should be able to push the "Down" button three times to start it back up.
If that does not correct the issue Please respond back I would like to assist you with any additional information. Hope this helps to some degree. -Matt
I TRANSPORTED A REFRIGERATOR FROM HOUSTON TO
sound like the condenser fan motor by the compressor has stopped and the not allowing the proper cooling check that also you should have waited at least 6 hr upright before starting the unit
10/23/2019 10:37:05 AM •
Frigidaire...
Answered
on Oct 23, 2019
Where is the temperature control knob on Frigidaire upright freezer model #CFFH17F1RW
The temperature control is located inside the freezer on upright models, and onthe left outside wall on chest models. The temperature is factory preset to providesatisfactory food storage temperatures.
However, the temperature control is adjustable to provide a range of temperatures for your personal satisfaction. If acolder temperature is desired, turn the temperature control knob toward COLD-EST and allow several hours for temperatures to stabilize between adjustments
