20 Most Recent
Frigidaire Model: PHSC39EHSS Questions & Answers
Ice maker not working properly
Hey, I would check water filter if it has one and the water line to water valve at the back of refrigerator. I'm thinking dirt or something when they work on water problem in other unit.
Water on the bottom inside the Freezer
the water usually comes from the evaporator defrosting and the drain being plugged with ice or frozen water. try a hair dryer and defrost the frozen water and clean the drain plug and hose
Flashes e f code
This is a combination of problems. I have a Kenmore Elite labeled Frigidaire model 253.44513601. If you are reading this you are aware that Kemore/Frigidaire refer's are JUNK.
I have went through TWO Kenomre Elites since 2001. My lateset Fridge (bought January 2007) suffered the "E F" code.
At first I replaced the Evaporator Fan (behind freezer compartment.) This did NOT solve the problem. I then bought a new control board located under the freezer. (take off toe plate, and removes screw, the board slides out and is connected by 3 wire harnesses.)
My fridge is now running, but it has yet to get "cool." This maybe because the User Interface needs to match the control board. Not sure yet, but I will keep posted.
Instructions to remove and install water actuator #241685704
getting access to the actuator. this is the procedure;
turn off the power
Remove the drain tray it just snaps out. remove the 3 screws behind the tray. carefully lift the panel up and out. There is a short control wire connecting the panel to the frig so be careful. remove the water hose from the outlet hole and remove the ice and water module.
its very easy
The drip tray will just slide out and then you will see the screws that hold the trim in place.
to get more complete details just click the link directly and get the proper diagrams
http://appliancejunk.com/forums/index.php?topic=282.0
if you have not had the fridge repair yet here is how to get in to the dispenser to get the actuator.
Feel or look along the bottom edge of the trim on the dispenser and you will see two slots.
Use a flat blade screwdriver to pry the bottom off.
Then slide the trim up and lift it off this will give you access to the screws to replace the actuator.
Here is a place to get Frigidaire parts
please do rate the solution.thank you for using fixya.keep updated.thanks.
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below
If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on.
Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service
https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer
https://www.justanswer.com > Appliance Repair
Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ...
1 answer · Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros
https://forum.appliancepartspros.com > posts > t55646...
Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video
https://www.appliancevideo.com > question > refrigera...
Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk
https://hvac-talk.com > vbb > threads > 53155-Frigidai...
Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ...
Domestic Refrigerator Short-Cycling
Dec 4, 2020
Wiring time delay for a short cycling compressor
Jun 23, 2022
Walk-in short cycles
Mar 7, 2021
Walk-in compressor short cycling
Oct 20, 2008
More results from hvac-talk.com
