20 Most Recent Frigidaire ULTRAWF Frigidaire PureSource Ultra Refrigerator Water Filter Questions & Answers
We had the same issue. My husband unscrewed the filter cover (1 screw on the left side of the filter under the light flap). Then he pushed the old filter in & lifted it up and it came right out.
Frigidaire... | Answered on Feb 25, 2019
Hi- not sure if it will help but I had issues getting it out. What I found is the plastic casing (fridge) needed a little twist/push. Play with it- hold the filter in and GENTLY push/pull/twist slightly the fridge housing.
Frigidaire... | Answered on Feb 14, 2016
Good Afternoon Friend,
I understand that the puresource3 water filter is leaking in your Frigidaire refrigerator. Please make sure that it is the filter leaking. Check for cracks in the filter. If the filter itself is not leaking, it might be something in the filter housing that is leaking. If this is the case, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing the leak. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Mar 07, 2015
Good Morning Joseph,
I see that you are having trouble with water dispensing and ice being produced on your Frigidaire refrigerator, even after replacing water filter, model# ULTRAWF, twice. I would suggest to reset your refrigerator, by either unplugging it, or shutting the power off at the circuit breaker for at least 2-3 minutes. Once power is restored try to get water out of the dispenser. If you are still having trouble with the water dispenser, remove the water filter and replace it, making sure you hear two clicks and the filter is flush with the filter housing. If these suggestions do not work, I suggest contacting your local authorized technician for further assistance.
-Best Regards-
WP
Frigidaire... | Answered on Apr 04, 2014
If you have a Frigidaire refrigerator with an icemaker, you may notice that water leaks from the icemaker from time to time. There are several reasons why this occurs, ranging from simple fixes to ones that are more complex. Once you notice leaking water, running through a quick checklist determines the problem, so that you can fix it.
Plastic Tubing Water Supply ConnectionsNo matter the type connection material used, it must be tight and secure so that no water leaks out. Check every place where a pipe connects to the appliance. Make sure the connection is tight and that there are no leaks. Ensure that the water supply valve is turned on completely. As you check each connection, watch that there are no drips. Tighten them if you catch any possible issue, as this could solve your problem.Clogged Condensation DrainWater can appear leaking from the icemaker when it is actually caused by a clogged condensation drain. The automatic defrost system occasionally turns on, melting any frost from the cooling coils. The resulting water falls into a drain sending it to a pan to evaporate. However, if ice from the icemaker makes it into this drain, it can clog it, and the water accumulates in either the fresh-food compartment or the bottom of the freezer in a side-by-side model. In a side-by-side with an icemaker, the water appears to be coming from the icemaker. Check the drain and clear it if there is a clog.
Ice Maker ValveIn Frigidaire models with an icemaker, a valve regulates the amount of water in the icemaker. If this valve malfunctions, a leak can result. The valve directs the water into cube molds. When obstructed by mineral deposits, the water sprays out of the molds. The water drips down and pools at the bottom of the freezer and onto the floor outside of the unit. Cleaning out the screen located at the end of the valve solves this problem.
Frigidaire... | Answered on Mar 11, 2019
Hi! Here you can find user manuals to Frigidaire fridges. Hope you'll find here the one to your fridge and fix the error. https://manualsbrain.com/en/brands/frigidaire/fridges
Frigidaire... | Answered on Mar 01, 2019
There is probably an object Some paper or mouse ( I have seen that one) coming into contact with the fan fins.
Diane - Sorry I don't have a Frigidare but check out this site - I have heard of this but your error code could actually be 5b which is the best that they can do to show a Sabbath Day setting that the frig is designed with
Check and scroll down this website to get the description way down on the webpage:
https://removeandreplace.com/2015/08/12/frigidaire-refrigerator-error-codes/
Frigidaire... | Answered on Feb 27, 2019
Google is your friend. Use it. Find the parts manual and discern how to access the handle mounting.
Frigidaire... | Answered on Feb 24, 2019
Frigidaire ULTRAWF Frigidaire PureSource Ultra Refrigerator Water Filter Logo
13 questions posted
Top Frigidaire Refrigerators Experts
Steve Allison
Steve Allison
Sal De
tom wright
tom wright
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
frigidaire water filter stuck
  • Refrigerators
