Hello Marc Donmoyer - Could the error code be SY CE? If so, then the refrigerator has detected a communication error at power up. Contact a professional to move forward accurately to check the wiring between main control board and user interface. Depending on the diagnoses, either or will need replacing.
Hello - Often when the refrigerator is inoperable and has no LED lights, it is because it could be something as simple as a damaged cord or an issue more complicated that requires the help of a professional. Check that the household circuit breaker has not been tripped or that any fuses are blown. Also, try reprogramming the refrigerator by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the fuses are working fine, however issue persists, then the refrigerator may be experiencing some form of a sealed system issue or a faulty electronic control board. At this point, I would personally recommend contacting a certified technician to accurately diagnose the unit to determine the root cause to reduce the risk of unnecessary parts.
Hello Todd Line - Often when the refrigerator is inoperable and has no LED lights, it is because it could be something as simple as a damaged cord or an issue more complicated that requires the help of a professional. Check that the household circuit breaker has not been tripped or that any fuses are blown. Also, try reprogramming the refrigerator by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If the fuses are working fine, however issue persists, then the refrigerator may be experiencing some form of a sealed system issue or a faulty electronic control board. At this point, I would personally recommend contacting a certified technician to accurately diagnose the unit to determine the root cause to reduce the risk of unnecessary parts.
Hello jcwilson2929 - If your ice maker has stopped producing ice completely, you can check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Hello jgamewell - Sounds like the dispenser could possibly have a broken or frozen door dispenser sealed. Contact a professional to move forward accurately to properly repair/reinstall part.
57 questions posted
750 Questions
598 Questions
459 Questions
272 Questions
173 Questions
