20 Most Recent Frigidaire FSC23F7D Side by Side Refrigerator Questions & Answers
Following a 4-day power failure,
There is a pan under the refrigerator that condensation drips into. Pull that pan out and clean it out. You access the pan by removing the front lower grill but some you have to pull the fridge away from the wall to access it from the rear
1/12/2018 7:23:26 AM • Frigidaire... • Answered on Jan 12, 2018
Frigidaire FSC23F7DSB0 Dispensing Water Causes Ice Tray Overflow
Computer board?...doubt it. This sounds like two solenoids (an electro-magnet that when energized sucks into it a mechanism, water valve etc)...the 2 solenoids might be sharing the same connection.
The two solenoids are "separate devices" and usually behind the fridge at the bottom. One is for water on the door and the other the ice maker triggers...although they might look like one whole solenoid as sometimes the water feed runs through it to feed the other. They are still "electrically separate."Look for something that got bumped / wire terminals touched together.
12/6/2017 1:20:48 AM • Frigidaire... • Answered on Dec 06, 2017
Condenser icing up
i would suggest the evaporator heater or thermal fuse (if applicable) has failed.
8/20/2017 2:31:32 PM • Frigidaire... • Answered on Aug 20, 2017
Drain pan underneath fridge is filling on a daily basis
The system is designed to evaporate that water using the warmth of the compressor.. is your compressor warm ? (the drip tray sits on top of it) I see that model has an Ic e maker... to check that the ice maker refill is not running on too long, switch off the ice maker, by lifting the wire arm that checks the level of the ice in the storage bucket.. leave it turned off for a day or two.. empty the drain pan, and check it again after 24 hours.. but if the ice is already full, the water problem may APPEAR to be resolved already, but will return when the level drops and the ice production begins again. If it is just condensate, then the drain pan should be able to contain the amount it produces, but 3-days straight, would indicate to me, that is not that... if your water pressure is good, it may be that the ice tray filler solenoid is being held open a fraction too long (maybe a second or so) and as the fridge is new, it will be making lots of ice to fill the container up,... so lots of small overfills.. mounting up to a full drain pan. Under normal use,.. other than parties and festive nights, when you use a lot, the water should evaporate faster than it is produced, but it shouldn't be happening at all.. if it is that, then turn the tap at the back of the fridge to where the cold water dispenser slows down slightly.. that should be enough to prevent it continuing.. IF that's the problem.
4/24/2017 10:53:03 AM • Frigidaire... • Answered on Apr 24, 2017
Side by side refrigerator side not cooling
Try cleaning the coils underneath the unit and if that does not work then see if you have ice building up on the inside of the freezer compartment on the back wall. If you do the you have a defrost issue which means either bad heater or thermostat and you will need service company for that. Good Luck
7/25/2015 4:03:43 PM • Frigidaire... • Answered on Jul 25, 2015
Frigidaire 2004 side by side, FSC23F7DWO flashing error code 2. Now what?
look at the lower half of the back of the freezer wall in the freezer,if you see frost you have a bad defrost heater ,control,or defrost thermostat.make sure the fan in the freezer and cond.enser in back are working. coil under ref may need cleaned,if you un plug for 10min listen, plug in. if you hear humm,and click.over load -relay is bad.
5/24/2015 5:52:55 AM • Frigidaire... • Answered on May 24, 2015
In door ice and water dispensing
sounds like the paddle is hanging up or the micro switch that the paddle actuates is sticking if you can see the micro switch spray some wd 40 on it open the door and work the paddle a few times
4/10/2015 3:26:21 AM • Frigidaire... • Answered on Apr 10, 2015
Where is control board on Frigidaire FRS26LF8CS1
Good Afternoon Friend, I understand you want to know where the control board is located, on your Frigidaire refrigerator, model# FSC23F7D. The control board is located behind the control panel itself. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to replace the control board with ease. Hope this is helpful. -Best Regards- WP
7/10/2014 6:38:55 PM • Frigidaire... • Answered on Jul 10, 2014
How do I repair ice maker and my water dispenser
Good Morning Friend, I understand that you want to know how to repair the ice maker and water dispenser on your Frigidaire refrigerator, model# FFHB2740PS4. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to repair the ice maker and water dispenser with ease. Hope this is helpful. -Best Regards- WP
7/10/2014 1:14:04 PM • Frigidaire... • Answered on Jul 10, 2014
T180581
check owners man.to make sure the dispenser is not on child lock.remove ice bin and try again to see if you hear auger motor run.if you hear motor,clean bin of all ice,also try turning motor fork at back of bin.should have resitance both ways and hear gears grinding.hope this helps.
4/17/2014 2:54:47 AM • Frigidaire... • Answered on Apr 17, 2014
0answers
Ice maker
Be the first to answer 4/11/2014 4:13:52 AM • Frigidaire... • Posted on Apr 11, 2014Be the first to answer
No frost on coils, compressor running, heater and
Hi Omar, I am happy to assist you. I understand there isn't any frost on the coils, and both the heater and thermostat are functioning properly. However, what exactly is your concern or the issue the unit is experiencing? Is the unit not cooling? Are you hearing the compressor? With this information I can better assist the issue at hand. Thank you and I look forward to your response.
8/22/2013 4:40:09 PM • Frigidaire... • Answered on Aug 22, 2013
Frigidaire FSC23F7D Side by Side Refrigerator Logo
132 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
dispense
  • Refrigerators
