20 Most Recent Frigidaire Refrigerator White Fridge & Freezer Handle Set - 5304485330 Questions & Answers
How to claim for lose of food when fridge compresour broke
contact manufacturer,
4/29/2016 5:18:31 AM • Frigidaire... • Answered on Apr 29, 2016
Filter pops out when water lever engaged
Hello Sammy, thank you for your post! I understand that the filter inside of your Frigidaire refrigerator pops out when you push in on the dispenser. This could be an issue with the filter. I would suggest reinstalling the filter and assuring that you can hear a connection within the housing. If the filter is not connected properly once water has pushed through it will dislodge from the housing. The housing could also be causing an issue within the connection. Is your filter a new filter? You may need to change it for the gaskets to be new. If you continue to experience issues I would recommend seeking help with a professional technician for a proper diagnosis to be completed. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
3/10/2016 2:48:00 PM • Frigidaire... • Answered on Mar 10, 2016
Fridge defrost drain pipe plugged
Hey Michael, thank you for your post! Based off what you have described your Frigidaire refrigerator drain pipe is plugged up. You can clear out any clog within your drain by performing a manual defrost. In order to defrost your refrigerator you would need to disconnect power from it for at least one hour. If this does not help your issue I would suggest seeking assistance from a professional technician. I hope that this information is helpful to you. -Matt
3/3/2016 2:59:10 PM • Frigidaire... • Answered on Mar 03, 2016
Need help, my Frigidaire refrigerator does work as it supposed to be. It works one side the freezer side only. What can I do?
call in a service technician or an accredited refrigeration repairer for a proper diagnosis and quote could be a faulty thermostat for the fridge side
1/20/2016 11:28:47 PM • Frigidaire... • Answered on Jan 20, 2016
The plastic tray at bottom in the fridge just above freezer compartment has a slight crack. Can this be repaired
Hi, they can be repaired with a plastic solvent glue usually comes in tubes. Make sure the tray is dry and at room temperature before putting the glue on. It should slightly melt the plastic and fuse it together. I would put another coat of glue on once the first coat is dry.
12/24/2015 6:48:40 AM • Frigidaire... • Answered on Dec 24, 2015
Where is the defrost timer on a FRC1560FF?
located where temp dial is in fridge side
12/21/2014 9:58:25 PM • Frigidaire... • Answered on Dec 21, 2014
How do i set the temperature
Turn the knob.
12/10/2014 7:42:12 PM • Frigidaire... • Answered on Dec 10, 2014
How much power does it draw, camping use
If you check the specs on the manufacturer website, it will detail an aprox yearly consumption.
3/25/2014 7:02:37 PM • Frigidaire... • Answered on Mar 25, 2014
0answers
I need to tighten the door handle on modle
Push the trim length wise, eg. place palms on upper trim, push down against trim and up, if forced it may crack so try it in lightly 1st. Just move it enough too tighten the door screws.
10/31/2013 1:13:52 AM • Frigidaire... • Answered on Oct 31, 2013
0answers
Fr340ff
Be the first to answer 5/28/2013 5:10:42 PM • Frigidaire... • Posted on May 28, 2013Be the first to answer
0answers
Frigidaire gallery series dishwasher bottom door seal keeps falling out
Did you clean the surfaces thoroughly and glue it down with white or clear silicone, then leave it to cure? also was it an OEM replacement or an Amazon special as the quality is different.
12/2/2023 7:59:45 PM • Frigidaire... • Answered on Dec 02, 2023
Frigidaire Upright Freezer keeps cycling on and off in short cycles
It is called short cycling. Help below If your refrigerator is short cycling, it can be caused by a number of issues including: An incorrectly set thermostat inside your refrigerator. Dirt and dust on the coils that prevents efficient operation. Faulty capacitors or relays that prevent the compressor from staying on. Apr 14, 2019
Possible Causes For a Short Cycling Refrigerator
A to Z Appliance Service https://atoz1.com > News
I have a frigidaire freezer and its short cycling, it runs
JustAnswer https://www.justanswer.com > Appliance Repair Sep 30, 2014 - i have a frigidaire freezer and its short cycling, it runs about 6 to 10 minutes and then cuts off. what can be the problem and how can we fix ... 1 answer ยท Top answer: OK so there are only 2 things that can cause this issue---either the defrost timer or the thermostat ...
Frigidaire S/S not cooling, short cycling
Appliance Parts Pros https://forum.appliancepartspros.com > posts > t55646... Freezer or fridge does not cool at all. Evaporator fan runs, compressor try's to start and will hum/buzz for approx 7-10 seconds then an audible click and stops ...
Refrigerator short cycling and not cooling very well
Appliance Video https://www.appliancevideo.com > question > refrigera... Compressor turns on during the short cycling and does produce cold air and cold lines going to the evaporator in the freezer. biggest thing is during the 3 ...
Frigidair freezer compressor cycling on/off
HVAC-Talk https://hvac-talk.com > vbb > threads > 53155-Frigidai... Mar 7, 2021 - My Frigidaire freezer (upright) Model #FFU13F9GW is cycling. I hear the compressor try to kick on then shuts off after about 10 seconds. This has been ... Domestic Refrigerator Short-Cycling Dec 4, 2020 Wiring time delay for a short cycling compressor Jun 23, 2022 Walk-in short cycles Mar 7, 2021 Walk-in compressor short cycling Oct 20, 2008 More results from hvac-talk.com
11/26/2023 9:05:58 PM • Frigidaire... • Answered on Nov 26, 2023
2answers
I have a code 56 on the panel of my Frigidaire side by side refrigerator. I unplugged the unit and plugged back in but the code is still there. None of the buttons work on the panel.
Diane - Sorry I don't have a Frigidare but check out this site - I have heard of this but your error code could actually be 5b which is the best that they can do to show a Sabbath Day setting that the frig is designed with Check and scroll down this website to get the description way down on the webpage: https://removeandreplace.com/2015/08/12/frigidaire-refrigerator-error-codes/
10/23/2023 3:50:36 PM • Frigidaire... • Answered on Oct 23, 2023
Frigidaire Refrigerator White Fridge & Freezer Handle Set - 5304485330 Logo
17 questions posted
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Refrigerators
Most Popular Question
18 2 cu ft in inches
  • Refrigerators
