I have changed the ink several times. Each time it works for about 30 pages and then gives me this error message again.
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
This
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
This
SOURCE: I have replace the black
Press and Hold the
STOP/RESET button or Cancel/Resume button and wait until it self restart.
Release the
STOP/RESET button when the printer is restarting
SOURCE: Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
SOURCE: Wrong Cartridge Error Message
The Print Head might be the fault of that,try replacing the print head and see if that helps
SOURCE: error code: U150 The following ink tank cannon be recognized (Cyan)
U150 ink error fixed!
I too was getting the error for unrecognized ink cartridge. Then the
little green circ board fell out of the end of the ink cartridge and it
hit me that maybe if I put in the little green circ board from the old
ink cartridge of the same color, then maybe the ink cartridge would be
recognized. It worked! So don't throw out an ink cartridge that still
has ink just because of that error and hold onto your empty cartridges
in case you need the little green/gold circ boards.
This works!
SOURCE: the ink cartridge cannot recognized (refilled 3 times)
i am having canon pixma ip1300 inkjet printer. it worked properly till 13th april 09 i got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to make my printer work again. give me the remedy as quickly as possible Thank you
