20 Most Recent Epson Stylus C86 InkJet Printer Questions & Answers
5answers
Resetting Printer Chip
Check your reference book[on the Cd] to try to determine the cause of the particular error. If you have used ssc[righ click on the icon in the tool bar] and thern reset all. Also take a look at www.fixyourownprinter,com and type Epson stylus C86 in the search bar.
4/17/2024 11:33:47 AM • Epson Stylus C86... • Answered 2 days ago
Replacing ink cartridges Epson Stylus SX215
Here's a tutorial on how to do it: Solved Epson printer doesnt recognize Ink Cartridge
8/5/2018 11:42:39 AM • Epson Stylus C86... • Answered on Aug 05, 2018
2answers
How to install destop printer in ubantu
1. Just hook up your printer to your linux machine and reboot your system
2. your system will automatically detect and installs your printer.
3. If not, then goto control panel .. find printers settings from there and manually add the printer. You may have to select your exact printer model while adding your printer manually to the linux machine.
I hope this is helpful to you.
Thanks
6/4/2018 11:26:19 AM • Epson Stylus C86... • Answered on Jun 04, 2018
2answers
Jamed paperc86 paper is jamed
Epson Stylus InkJet Clear a paper jam in printer
8/3/2016 5:38:56 PM • Epson Stylus C86... • Answered on Aug 03, 2016
3answers
General error On Epson R230 / head not comeback in home position
2 red ligh blinking & show general error
4/10/2016 3:13:05 AM • Epson Stylus C86... • Answered on Apr 10, 2016
My printer says errror do not recognise cartridges. they are genuine epson and worked fine yesterday
If that message comes, you have to try with another new cartridge. Just because it worked the previous day, doesn't mean it should work the following day. Once, when I refilled and used it, it worked and didn't work the following day. So try with a new cartridge and check the expiry date as well. You should take it to the dealer, if you have the receipt and he will gladly change for a new one. It happened to me once!
11/16/2015 11:39:49 AM • Epson Stylus C86... • Answered on Nov 16, 2015
EPSON Stylus c86 with CISS - color and power led lit contantly
Download this file Epson Adjustment Program to reset your printer blink lights because the ink counter of your printer is full and need to reset to zero
9/26/2015 5:51:49 PM • Epson Stylus C86... • Answered on Sep 26, 2015
How do i reset Epson c84 ink cartridge
I am finding some truth to comments about unused ink cartriges In the > Stylus C84 registering as empty when they still sound full(colors go > empty even when you just print black). I am wondering how safe it > would be to use an chip resetter on a cartrige without refilling it and > allowing it to print until it truly is empty. Would there be a risk of > some air getting injected into the head (when the cartrige runs out), > thus ruining another printer (already went through one printer and got > it replaced through warranty, but I think that was just from leaving > the printer unused too long -- I don't have a resetter right now). >
7/13/2015 7:39:44 AM • Epson Stylus C86... • Answered on Jul 13, 2015
HOW DO I FIX EPSON C8600 E520 ERROR?
This site: Thread Epson Aculaser C8600 Service Req E520 says, "If you're not a technician, I'd suggest doing what the error says and calling a qualified service organization."
6/15/2015 6:27:56 PM • Epson Stylus C86... • Answered on Jun 15, 2015
EPSON E520
E520 is an error of the 2nd BTR (2nd rollers of transfer)
2/26/2015 7:31:00 PM • Epson Stylus C86... • Answered on Feb 26, 2015
My epson stylus tx121 cannot recognize my cyan ink
All you need to do is to reset your device using the software resetterthis link :http://www.4shared.com/get/Tct88J0Z/ME320-TX121.html;jsessionid=915B4C7E4E51E44E0A13252FEA1C0E4F.dc516Download the software run the program,accept the condition given and select the particular adjustment or do this steps;1. Download the ME32 T121X RESETTER, extract it to your designated folder.2. Run the Adjustment program and click ACCEPT to continue.3. Click model name ..there are two options.ME 32 or T121X .4. Click DESTINATION or location at present then click ok.5. Click PARTICULAR ADJUSTMENT MODE then select WASTE INK PAD COUNTER.Then click OK.6. Check two boxes the MAIN PAD COUNTER and FL BOX COUNTER then Click INITIALIZATION.7. Icon box prompt and you to turn on and of the printer device>>then its all DONE>>>
6/12/2014 4:19:53 AM • Epson Stylus C86... • Answered on Jun 12, 2014
How to reset epson stylus TX121x
unplug, hold power button for 30 seconds
6/6/2014 6:53:49 AM • Epson Stylus C86... • Answered on Jun 06, 2014
Why can't I print with only black ink when a color ink cartridge is empy??
the Printer requires a fully operations set of cartridges to print. Some models of printer WILL allow black only printing - but not all. Are you sure there fore yours will? But still a fully operational set of carts are required to be on board. check out - www.fixyourownprinter.com
4/12/2014 1:04:36 PM • Epson Stylus C86... • Answered on Apr 12, 2014
How do I clean my printer heads
When it comes to printer issues, there are few things as frustrating as expecting a clearly-printed document and ending up with something that looks like a cross between a Picasso and a Rorschadt blot. If you notice that the print quality of your documents has decreased considerably or if you are bringing an old inkjet out of retirement, you need to clean the print head to ensure you?re getting the best from your printer. A dirty or clogged print head will hinder a regular flow of ink from the ink cartridge to paper. The first step is actually knowing where the print head is and what it does. As you print a document, ink droplets leave the ink cartridge through the cartridge?s nozzle and go to the print head. The print head then lays the ink on a precise point on the paper. As you print, tiny droplets of ink can get stuck around the print head opening. If these drops get time to dry, they can form a crust around the print head opening and cause it to print poorly. Clean It With Software There are a few ways to go about cleaning the print head. Potentially, the easiest way is to let your printer clean itself. Many inkjet printers will have maintenance options in the printer?s software that will actually clean your printer for you. We used a streaky Canon BJC-80 for our testing, and the driver we installed on our system for this inkjet had quite a few maintenance options. (Keep in mind that the process for cleaning your specific printer?s print head may be slightly different than what we?re describing here.) To check these out in Windows XP, click Start and then Printers And Faxes. Right-click your printer and then Printing Preferences. This displays the Canon Bubble-Jet BJC-80 Printing Preferences dialog box, which houses various layout and print-quality preferences, as well as the printer?s maintenance options. Click the Maintenance tab to view what your printer can do from a software perspective. Our printer has two cleaning modes?Cleaning and Deep Cleaning. Cleaning isn?t quite as time-consuming as the Deep Cleaning mode, but Deep Cleaning mode does a more thorough job and can resolve some issues that the normal Cleaning mode can?t. Just click the proper cleaning mode to start it and let the cleaning process run its course. You may have to do this a number of times to get the print head clean. If you don?t see a maintenance tab, it doesn?t necessarily mean your printer doesn?t have a self-cleaning function; it just means that it doesn?t use commands from your computer to do it. For instance, on the BJC-80 you can also start the cleaning process by holding down the Resume button until you hear two beeps. Check your printer?s manual for ways to clean your print head. Clean It Yourself Some software bundles that come with printers have cleaning functions that you can use to clean your print head. If the built-in cleaning functions don?t seem to do the job, there are a few ways to clean your print head manually. Some swear by isopropyl alcohol, while others believe in just plain ol? water. When used correctly, either can help your printer perform better. First, remove your ink cartridges from your printer and then dip a cotton swab in hot water or isopropyl alcohol and rub it against the print head. This should loosen any crusted ink. Some printers, such as many Canon models, feature removable print heads that give you easy access to the print head and its nozzle(s). Many other inkjet printers don?t have this feature, so you?ll have to do your best to work around parts in your printer. Be careful, especially if you use isopropyl alcohol to clean your print heads: Some printers use rubber gaskets; if you get isopropyl alcohol on the gaskets, it could dry them out. If you have a removable print head, remove the ink cartridge from the print head and take the print head out of your printer. Put some isopropyl alcohol or hot water into a saucer and set the printer head in the saucer. Let it soak for at least an hour. If it?s really dirty, it might be a good idea to let it soak overnight. Let it air dry, reinstall it in your computer, and run a cleaning cycle. This should get rid of any dried ink that was loosened during the soaking.
4/10/2014 11:45:22 PM • Epson Stylus C86... • Answered on Apr 10, 2014
2answers
Free installer EPSON STYLUS T10
1/31/2014 1:47:29 AM • Epson Stylus C86... • Answered on Jan 31, 2014
Test page shows there is ink, but when I attempt to print a document it is barely the ink is not dark at all
It sounds like the print head nozzles are clogged. Check your online user's manual (if it is not on the install disk that came with your printer) for the cleaning procedures. Here's a link if you can't find it: http://files.support.epson.com/pdf/xp400_/xp400_qr.pdf go to the section, "Checking the print head nozzles"
11/24/2013 1:41:57 AM • Epson Stylus C86... • Answered on Nov 24, 2013
Epson Stylus C86 InkJet Printer Logo
501 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
  • Office Equipment & Supplies
