20 Most Recent Canon PIXMA® MP210 Printer Questions & Answers
Canon MP210 no power
See that power cord is seated on both ends, Plug cord into wall and with a multi-meter see if you are getting voltage on other end of cord. Test wall socket. Try another wall socket. Replace cord.
3/30/2015 1:23:42 AM • Canon PIXMA®... • Answered on Mar 30, 2015
Do i need both the colour cartridge and the black and white cartridge in the printer for the it to print on the black and white
you should be able to go to print preferences and choose fast economical ,greyscale- black ink only
Should be something like that most printers
12/7/2014 3:07:19 AM • Canon PIXMA®... • Answered on Dec 07, 2014
Taking tape off original printer
Remove it if blocks installation of cartridge
3/24/2014 7:12:01 AM • Canon PIXMA®... • Answered on Mar 24, 2014
0answers
E4 error
Be the first to answer 12/5/2013 10:43:24 PM • Canon PIXMA®... • Posted on Dec 05, 2013Be the first to answer
My canon mp20 just pulls the paper and displays
I was pretty disappointed and had bought this last year at walmart. i had the same problem after only a couple months, and was hoping to use it for my business/work but now stuck with a broken printer =( please advise, tried all the suggestions people have given and it still doesn't work and there is no paper stuck in it, just says no paper.
3/7/2013 4:07:00 AM • Canon PIXMA®... • Answered on Mar 07, 2013
Can a canon mp210 scan 35mm negatives
I've had a quick look at the specs. and it doesn't look as though it will.If you need more help, here's the canon web site for your printer, you can download user guides and software from the support page.Another clue, assuming you bought it from new, were it able to do so, you would have a small fame to hold the negatives for scanning, also check the software, again if able, there would be a setting for negatives in the scan preferences software.
11/21/2012 5:55:34 PM • Canon PIXMA®... • Answered on Nov 21, 2012
Canon printer mp210 installation
That cable should be a usb-2 to a mini-usb. There should be a jack on the lower left as you look at the back of the printer for the mini-usb. The USB end plugs into a USB jack on the back of your tower. murf427
8/30/2012 3:44:43 AM • Canon PIXMA®... • Answered on Aug 30, 2012
Canon MP210 not functioning
Check Device and Printers in Contol Panel then check if your printer appears in there. If it is not present, something has gone wrong with the drivers. What you need to do now is to reinstall the driver. And it can be found on this link http://usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210?selectedName=DriversAndSoftwareOnce on this page, select the operating system of your computer. Check if its windows vista, windows 7 or windows xp. After that hit the download button. Just run the drivers once the download completes.
11/19/2011 5:27:11 PM • Canon PIXMA®... • Answered on Nov 19, 2011
2answers
Canon MP220,error u162.ink cartrigde full?
Press and Hold the STOP/RESET button or Cancel/Resume button and wait until it self restart.
Release the STOP/RESET button when the printer is restarting
10/17/2011 4:02:52 PM • Canon PIXMA®... • Answered on Oct 17, 2011
The printing is wavy coming out of the cannon
You should try to do a Print Head Cleaning cycle.
Follow by an Aligning the Print Head procedure.
Page 29 & 31 of your Quick Start Guide.
3/25/2011 7:19:53 PM • Canon PIXMA®... • Answered on Mar 25, 2011
The waste ink absorber is full
Reset Waste Ink Counter Canon Pixma MP210 and Canon Pixma MP220
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
  5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
12/30/2010 5:48:19 PM • Canon PIXMA®... • Answered on Dec 30, 2010
Impossible to insert the cartridge in a printer
  1. After confirming that the printer is powered on, open the scanning unit (printer cover).The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support <1> is fixed into position, release your hands.
    *MP470 shown
  2. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  3. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  4. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  5. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  6. Fold the scanning unit support and close the scanning unit (printer cover).
  7. Wait until the preparatory operation is complete; it takes about one to two minutes.
Removing Ink Cartridges:
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
  2. Press down on the semi-circular tab to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Fold the scanning unit support and close the scanning unit (printer cover).
11/30/2010 7:08:32 PM • Canon PIXMA®... • Answered on Nov 30, 2010
Como soluciono el error 6000
Hay un sensor en esa puerta principal que discierne que es abierto.quita la puerta principal, el alcance en la ranura en el lado izquierdo de la apertura, desliza el sensor retrocede, y vuelve a instalar la puerta al tener el sensor arriba. I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
11/16/2010 4:57:36 AM • Canon PIXMA®... • Answered on Nov 16, 2010
What black ink cartridge is used for this model
Hello, it's Canon #40 or #30 black ink.PG30 and PG40 is the model of the ink. The model of the printer is MP210.
Thanks, Lolita
10/26/2010 9:44:48 PM • Canon PIXMA®... • Answered on Oct 26, 2010
My canon pixma mp220 disc will not load to install
You have to download the driver from Canon's website.
You can do it from this link:
http://www.canon.co.uk/for_home/product_finder/multifunctionals/inkjet/pixma_mp220/index.asp
9/21/2010 12:15:02 PM • Canon PIXMA®... • Answered on Sep 21, 2010
Canon PIXMA® MP210 Printer Logo
61 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
waste ink absorber full
  • Office Equipment & Supplies
