20 Most Recent
Brother MFC 490cw Color Inkjet Multi-Function Printer Questions & Answers
Brother mfc490cw error message unable to clean 5a
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Brother Printer Setup & Support Call 1-(805) 225-6690 We are 24 Hour Available Call Now For Help...
The disconnect-problem was caused by the settings of the WiFi-router.
The settings are:
Capture(wlanadv.beacon)
Beacon Interval:
Capture(hwlad2.def)
Default: 100,
Capture(hwlad2.milli)
Milliseconds,
Capture(hwlad2.range)
Range: 1 - 65535)
Capture(wlanadv.dtim)
DTIM Interval:
Capture(hwlad2.def)
Default: 1,
Range: 1 - 255)
Capture(hwlad2.frathrh)
Fragmentation Threshold:
Capture(hwlad2.def)
Default: 2346,
Range: 256 - 2346)
Capture(wlanadv.rts)
RTS Threshold:
Capture(hwlad2.def)
Default: 2347,
Range: 0 - 2347)
This gives an optimal performance of the router, The default setting work fine for the printer, but gives less performance.
I now use a seperate wifi-router for the printer.
All is fine now.
The Scanner of my MFC
Install the Brothers Paper Port program and see if that helps. Usually comes with CD you have with machine but can be down loaded...
When scanning to ocr I get brccMCtl.exe has
I deleted all Brother programmes from by PC, cleaned the registry and used the Brother Uninstall programme first. (I restarted the PC after each deletion)
Then I reinstalled the latest Brother printer driver software without the PaperPort SE 11 programme.
Then I installed the Paperport programme separately.
It worked.
Thanks
