Maytag MAH8700A Front Load Washer Logo
Anonymous Posted on Sep 23, 2011
Washer Flashing Error Code ND; door won't open after turning washer off
Anonymous
Level 3:
  • Master 2,341 Answers
  • Posted on Sep 23, 2011
Anonymous
Master
Level 3:
Answers
2341
Questions
Helped
636874
Points
7414
The ND error code means NO DRAIN. ,
The usually reason the door remains locked once the cycle is over is because the filter screen on the drain pump is blocked so not all the water could drain out...the door lock is tied into the pump and until the pump tells the control board that the wate r is out the door will not unlock. This tip i wrote will show ya how to take apart the washer to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
2answers
My Maytag Neptune washer has "np" flashing. The door is locked and the cycle is not complete
Are you sure this is not an nd and not an np flash code? If so then the code stands for no drain, likely something is clogging the washer pump inlet.
Washer won't drain
Most likely pump is blocked or broken.
2helpful
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
3helpful
2answers
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
1helpful
Door won't open on whirlpool duet washer frontload
Press the cancel button twice to cancel the error code. There should be an error code flashing -- for example 'F02'.
19helpful
3answers
Amana front load washer error code "nd". Door is
Hello there and welcome to fixya
From what you're describing it sounds like the drain pump is blocked. The nd error code indicates "no drain". If the unit can't drain it won't spin. You're going to have to slide the washer out far enough to remove the rear panel; be careful not to damage the floor. Once you get the rear panel off you will see the pump. Be sure to have plenty of towels & a small container to catch water. I am sending you instructions from the service manual to remove and replace the pump. Another possibility is the drain line is blocked or something is stuck in the tub to pump hose.
ERROR CODE NP AND NOW DOOR WON'T OPEN
Hello first try unplugging the machine for 7 minutes if this doesn't then allow you to open the door then you can manually release the door lock by taking off the dispenser assebly holder (bezel) and pulling on the door lock release cord you will find inside. Also as far as the nP I think the erro your seeing is ND which is no drain in which you can click this link
http://www.fixya.com/support/t340703-maytag_neptune_error_code_nd another tech has posted with pictures on this issue. IF you have any further questions message me back Thanks
Rick
My amana front load washer has Nd flashing and won't open door? What does Nd stand for?
The ND error code means NO DRAIN, why it comes up is because the computer thinks that within the normal times it takes to drain the water from the tub it hasnt drained in that time.
Things that will cause it to not drain in the normal time is oversudsing becuase too much detergent was added.
Or something such as lint in the drain pump filter screen restricting the water flow into the pump
Gene
I have an error code of nd on my washer
If your washer is beeping, and the display is flashing "Nd", your debris filter may be clogged. To check for a clogged debris filter, goto back of machine, look for little door at bottom remove cover and remove filter and clean
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
