20 Most Recent Maytag MAH8700A Front Load Washer Questions & Answers
In my case it was a old connector harness located on your motor. Leads comming from tacho ( 2 red wires) were not passing thru harness. I rilpped them off and made solid but crimps.
Hope this helps a little.
Maytag MAH8700A... | Answered on Mar 17, 2019
Close the water faucet slightly to reduce the speed of the flow into the the soap drawer...The machine will fill a little slower, so what??!
Maytag MAH8700A... | Answered on Nov 03, 2017
There seems to be some sort of blockage before the pump.You may have a blockage at the point where water drains from tube. Good Luck Friend.
Maytag MAH8700A... | Answered on Oct 15, 2017
Would be the Inlet solenoid (this is effectively the valve that allows water to come in - that the inlet hose screws on to, and has a couple of wires going to it on the inside).
Replace carefully, with the power shut off, or simply turn the tap off when not in use :-)
Maytag MAH8700A... | Answered on Oct 01, 2017
"ND" refers to a No Drain issue . check for restrictions in the pump assembly, restrictions in the drain hose, loose wire at the pump, or it's a bad pump.
Maytag MAH8700A... | Answered on Jun 26, 2016
I have checked the tech sheet for your washer there is not any F codes only E codes. The two you have listed are for the stuck button. It sounds like someone was playing with the buttons and held the button for more that 30 secs. Then possible put it in child lock. If you need more help please let me know.
Maytag MAH8700A... | Answered on Apr 03, 2016
if you remove the oval cover in the back of the mach,you will find the pump.there are 2 hose clamps to remove.usually you will find change stuck in the pump.remove the screws on the bracket that holds down the pump and you can take the entire pump out...good luck
Maytag MAH8700A... | Answered on Jun 14, 2015
need to replace mainboard
Maytag MAH8700A... | Answered on Aug 12, 2014
I had this problem solved by changing this control board:
Whirlpool Part Number 34001494: CNTRL-ELEC I bought this from AMAZON for under $ 200, was able to change myself, good luck
Maytag MAH8700A... | Answered on Jun 12, 2014
You need to open the water pump to see if it is clogged with any thing causing the obstruction for not draining.
Maytag MAH8700A Front Load Washer Logo
359 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
code sr mean maytag neptune
  • Washing Machines
