20 Most Recent Maytag Atlantis MAV6000 Top Load Washer Questions & Answers
Your problem sounds like a broken belt . Check and replace. Good Luck Friend.
Maytag Atlantis... | Answered on Jan 30, 2018
When you opened the lid to add clothes, your Maytag sensed a door lock fault and went into protective shutdown.
Maytag Atlantis... | Answered on Jan 04, 2018
it sounds like there is something stuck in the water pump you will need to lay the water outlet on the floor into a shallow vessal to empty it then that the back off locate the water pump and see if you can rotate the cooling propeller if not take the motor housing apart to remove the debris that's preventing it from turning if the motor has not burnt out eric
Maytag Atlantis... | Answered on Jan 01, 2018
Hi Greg.
this is all i could find,go to this link and see if it helps you out.
Maytag Atlantis washer Model MAVT754EWW how to clean the hose Screens that...
Maytag Atlantis... | Answered on Nov 04, 2017
The model number would help, ya know?
Maytag Atlantis... | Answered on Oct 03, 2017
I would not fix it myself .
Maytag Atlantis... | Answered on Aug 23, 2017
Press 2 metal tabs. About 6" from the sides on the front of washer. Plastic ring on top has tabs that need to be disengaged to disconnect the ring. Once ring has been removed the area between the plastic tub & metal tub is accessible. Check for small articles of clothing, like socks or underwear. Inner tub can be removed by: snap up plastic cap (small slot for tool to slip in and pop up). Remove 7/16 nut and remove agitator (may require to be rocked back & forth, sits on a splined shaft). Remove 5 small phillips screws, being careful not to drop any, and pull inner metal tub up (may require it being shimmied back and forth). Removing this tub will give full access to any debris or articles of clothing that may be under it. Please keep in mind that if you're challenged in reassembly
Maytag Atlantis... | Answered on Jun 16, 2017
Go to www.repairclinic.com and enter MAV6000. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly and replacement.
Maytag Atlantis... | Answered on May 24, 2017
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Maytag Atlantis... | Answered on Apr 26, 2017
Maytag Atlantis MAV6000 Top Load Washer Logo
1,252 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
remove maytag inner tub
  • Washing Machines
