20 Most Recent
Samsung WF306BHW High Efficiency Front Load Washer Questions & Answers
Machine only one direct rotation (Clockwise) even stop and can't be continue to working at all washing programme
it could be that the water sensor is not Working properly telling the programmer that there's water in or out of the machine unplug the machine take the back off and locate a small 5mm pipe leading upwards take it off and blow gently into it you should hear a click and one when you let the air out if so the place you took the pipe from is blocked not allowing the sensor to work correctly use a pipe(smokers) cleaner or metal rod to clear refit the pipe and rear panel run machine eric
I need to move my Samsung front loader washer
Certainly. Treat it gently and don't jar it and expect to be sprinkled with a little water and you will be fine.If moving/tilting it causes damage it will be because it wasn't in good condition.
Fitting the transit brackets it was supplied with when new would make the process much more secure.
I have a Samsung WF316LAS/XAA
take off the top and check the hose that leads to the tub may be plugged . May have to take the boot(door)seal off front under door to access lower end.
