20 Most Recent Frigidaire Affinity ATF7000E Front Load Washer Questions & Answers
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
Frigidaire... | Answered on Apr 01, 2019
Error Code ( E-23 )--------Clean the LID LOCK sensor,its almost located where you can see the LID LOCK came OUT and IN or Moving--which is functions to LOCK and UNLOCK the door cover ( Symptom ++ the LID LOCK will moving OUT and IN),open all the cover ,take out the LID LOCK sensor,open the LID LOCK sensor case until you can reach the COPPER connector which is act as the SWITCH .CLEAN the COPPER with paper sand or anything possible but not to damage the copper.After all put it back to the place intact.Hope it work,Mine worked with this procedure.+++++Toshiba AW-SD120S COST=== FREE OF Charge ( Do It Yourself )
Frigidaire... | Answered on Jan 03, 2019
If the PAU error does not clear after properly restarting the washing machine cycle, push "Cancel," then disconnect the power cord. Wait a few minutes and restore power to see if the error code goes away. If not, the control board may need to be replaced.
Frigidaire... | Answered on Oct 21, 2018
We have a code of efo
Frigidaire... | Answered on Jul 04, 2018
I just tried all manner of bending, pushing and prying the drum baffle. Can't get it to move. I'm thinking I need to break it to clean behind it then install a new drum baffle. At $49.35 plus tax and shipping I'll leave the coins there for now.
Frigidaire... | Answered on Mar 24, 2018
Good Afternoon Friend,
I understand that you are having trouble with your Frigidaire Affinity dryer not heating up. There are some things that you are able to try. First check to make sure that the lint filter, the ducting, and the outside vent, are clear of lint and not constricted in any way. Second, reset your appliance by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. Once power has been restored, run any cycle. If you are still noticing that your dryer is not heating, I suggest contacting your local authorized technician for further assistance. They should be able to diagnose your dryer and determine why your appliance is not heating. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Dec 28, 2017
please go tp the manufactures website and download the user manual its normally free and look in the trouble shooting section eric
Frigidaire... | Answered on Dec 27, 2017
It's the timer control, not the motor or filter. Try a different setting. You should also be able to find more information on the manufacturers website, along with a manual and possibly a diagram. Also You Tube is a good place to find out more on how to repair it.
Frigidaire... | Answered on Dec 03, 2017
You need to lean it back and remove the lower panel, you will have complete access to the water pump, disconnect hose clamps,remove and clean the rubber boot,disconnect electrical connector and 2 screws holding pump, Replace with new pump, before beginning take pictures to ensure proper installation
Frigidaire... | Answered on Nov 19, 2017
I would give it back and enact the warranty.
Frigidaire... | Answered on Nov 09, 2017
I understand that your Frigidaire Affinity dryer, model# ATF7000E, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home'sicon1.png circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Frigidaire... | Answered on Oct 20, 2017
I would be looking at drain pump for obstructions or pump may have failed
Frigidaire... | Answered on Sep 29, 2017
Frigidaire Affinity ATF7000E Front Load Washer Logo
1,529 questions posted
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
fix error e23 toshiba washing machine
  • Washing Machines
