20 Most Recent Maytag Neptune MAH5500B Front Load Washer Questions & Answers
you dont need to reset the times, all that has changed is the soil type. in example, light, regular or heavy. that is what causes the times to change.
you just need to push the options button until it shows the type of cycle you want.
also make sure you have the proper cycle selected and then look to see what other options are selected. you just have too many options turned on, so look at the controls to see what is different then you remember.
Maytag Neptune... | Answered 3 days ago
does it say do in the display as if the door is open??
Maytag Neptune... | Answered on Nov 23, 2018
Try spin only cycle. Should drain water then spin. If that doesn't work it may be the power outage started as a power spike and fried your control board. Good luck.
Maytag Neptune... | Answered on Mar 01, 2018
the sensor is not working properly
Maytag Neptune... | Answered on Feb 23, 2018
well logically as superintendent you would be contacting the manufacturer of the machine and getting the details from them
or better still the land lord should be getting the details and passing them on to you or have the service agent come in and do the job for you as the cost is a tax deduction for him
Maytag Neptune... | Answered on Feb 05, 2018
there could be a multitude of reasons for this I would call an engineer for a quote first eric
Maytag Neptune... | Answered on Jan 17, 2018
Suggest use detergent designed specifically for your model.
Maytag Neptune... | Answered on Jan 16, 2018
Non HE detergent will cause your front load washer to have odors. If you do use HE detergent and still have the problem,use the "AFFRESH" product in the washer to neutralize the odor.
Maytag Neptune... | Answered on Jan 11, 2018
If you mean your laundry sink, then mix 1 cup baking soda and 1 cup vinegar together and pour it into the drain. Let it sit in the drain for a few hours and then flush the drain with hot water. If you are tslking anout your washing machine you can buy a washing machine cleaner to get rid of the smell.
Maytag Neptune... | Answered on Jan 09, 2018
The "FL" is indicating that the door has failed to lock or it locked but the control does not sense the door has locked.
It could be caused by:
faulty door lock solenoid
loose wire connection
faulty door lock switch
faulty door lock sense switch
bad control board
I recommend calling a service technician to diagnose and repair your washer.
but try this first just in case....unplug it for 1 minute plug back in and see if the fault code clears.
good luck.
Maytag Neptune... | Answered on Jan 03, 2018
goto ( https://www.maytag.com/ ) click on service then on contact us
Maytag Neptune... | Answered on Dec 21, 2017
The best suggestion I can givefor this is to use a tablet called Affresh.
http://www.affresh.com/
This is a great cleaner for all HE washers. I hope this helps.
Good Luck!
Maytag Neptune... | Answered on Dec 15, 2017
here is a website you can view a bulletin on the error code DC pertaining to your washer
http://fixitnow.com/wp/2009/06/11/e3-and-dc-error-codes-in-maytag-mah6700-8700-and-9700-washing-machines/
Maytag Neptune... | Answered on Dec 01, 2017
There is a 2" L shape hose connected to that drain hole under. You can unclog it using a soft plastic stick. Stick it on to that hole do not force it turn the plastic stick while putting it in. Thare are 2 types of door gasket on that model one has hole in it and the other doesn't. If your original doesn't have a hole, the one that has a hole will work but there is a plug on to that hole.
This is your door gasket
https://www.rcappliancepartsimages.com/dbimages/00003022/00909166.jpg
Just take the front panell off to see if there's a small hose connected to the gasket drain hole. You can even clean it after taking the panell off
https://www.youtube.com/watch?v=6O6d3KFIfWo
Maytag Neptune... | Answered on Nov 23, 2017
Maytag Neptune MAH5500B Front Load Washer Logo
3,972 questions posted
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
Neptune Maytag
  • Neptune Maytag
Most Popular Question
maytag mah5500bww front load washer drum
  • Washing Machines
