20 Most Recent Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Questions & Answers
Don't know what it is , but the 3 guys above me are wrong
Maytag... | Answered on Oct 17, 2018
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Maytag... | Answered on Jun 26, 2018
We had the same problem with our Maytag Centenial Washer. I simply removed the Auto Fill Sensor, cleaned the contacts with Deoxit contact cleaner and problem solved. All was done in less than 20 minutes.
Maytag... | Answered on Mar 27, 2018
The softener dispenser is supposed to get flushed during the cycle to prevent clogging. The flushing may not be happening in your machine and some residue could be clogging the discharge.
Maytag... | Answered on Nov 12, 2017
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Maytag... | Answered on Oct 30, 2017
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Maytag... | Answered on Aug 04, 2017
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
Maytag... | Answered on May 15, 2017
I would suggest that as it is a new unit , it is covered by warranty so why don't you call the service agent for a warranty inspection and fix rather than loosing your cool
there is nothing you can do while it is under warranty as any fix by other than authorized service persons will void the warranty
Maytag... | Answered on Oct 02, 2016
Dear Ed,
To save some money and effort, get an electric meter and check to wires to the water mixer to see if the electricity is coming to the mixer when you tell it to use the "hot".
Then, check the filter screen either in the hot water hose (found on either end) or the hot water connection in the mixing valve.
They can plug up with sediment preventing water flow.
Finally, you can change the mixing valve it you are sure the electricity is coming to it during the hot cycle, and you are sure the water is flowing freely out of the hot water hose.
God bless your efforts.
Maytag... | Answered on Nov 12, 2015
The drainhose could be kinked or clogged my brother had a small stocking in his.the drainhose could be too high no more than 94 inches
Low voltage can cause this no extension cord
To much suds too much detergent us a he High Efficiency detergent
Load unbalanced a single or bulky item may cause imbalance add more item or distribute the load
Maytag... | Answered on Jul 24, 2015
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
399 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
agitator top seems spin but clothes not
  • Washing Machines
