Refrigerators Logo
Tracy Chreene Posted on Jun 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Frigidaire Gallery fridge....it’s the one that is nothing but a whole fridge....model FGRU19F6QFB. We recently lost power for about an hour and afterbir came back on our fridge isn’t cooling properly. It’s staying around 55 degrees. We’ve tried unplugging it and letting it sit but so far that hasn’t helped. Any information will be greatly appreciated!
Jorgie the appliance guy
Level 3:
Top Expert:
  • Frigidaire Master 5,639 Answers
  • Posted on May 23, 2019
Frigidaire Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523937
Points
32630
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
1-3 TEMPERATURE CONTROL
As the food in the fridge gets colder, it gives off less heat, and the air inside the fridge will remain colder. A thermostat called aCOLD CONTROLwill cycle the cooling system on and off to keep the temperature inside your fridge within a certain range. You can adjust that range using one of the dials within your fridge.
On most fridges, all the cold air for both the food compartment and the freezer compartment is produced in one evaporator. Since the freezer is so much colder than the food compartment, most of the cold air that is produced circulates to the freezer compartment. Only a small amount is needed in the food compartment to keep it down to the proper temperature. This amount is adjusted by a smallAIR DOORin the duct between the evaporator and the food compartment. The control for this air door is the other of the two dials within your fridge.
If you hear your compressor "short-cycling" (starting and stopping at short intervals) try jumping across the two leads of the cold control thermostat ( in the fridge compartment) with an alligator jumper. You can also check both for live voltage current and ohms- If there is a greenthirdlead, ignore it for this test; it is the ground wire. If the fridge starts running constantly, the cold control is bad. Replace it.
To test or change the cold control, first Pull the knob off it and remove any plastic cover plate or housing from it.
You will see two wires leading to it. There will also be a thick, stiffCAPILLARY TUBEattached. The capillary tube is the liquid-filled temperature-sensing element of the cold control, and operates in the same manner as a thermometer
The air damper, baffle or diffuser is the device that balances the air flow from the evaporator fan housing. This normally is a mechanically controlled baffle or flapper that controls the amount of cold air entering the fresh food compartment. If the baffle is damaged or the linkage to the control knob is damaged, then you may not have enough cold air entering the fresh food compartment resulting in higher than normal temperatures. This baffle or damper will be located where the cold air enters the fresh food compartment.
Refrigerator Is Not Cooling What To Check And How To Fix How to Test your Defrost Timer
5 Related Answers
Anonymous
  • 709 Answers
  • Posted on Sep 25, 2007
SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
shaun greyvensteyn
  • 159 Answers
  • Posted on May 22, 2009
SOURCE: Stops cooling, need to unplug, plug back in and it works for a little while
if the motor runs it cant be the thermostat then it is low gas inside the system and it must be cold after 30min
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on Jul 16, 2009
SOURCE: Freezer works fine--Fridge Side Not Cooling Properly
I am sending you a link below to download the manual for your model. There are too many Q&A to do this here and on this page. The manual has some self diagnostic test you can do yourself through the control panel. These are very good refrigerators and they are backed by Maytag. The only problem is they are complex. You can try to find answers and if you have questions I will need to be contacted by email because Fixya has not been sending out anyones responses lately. They know about the problem. Sea Breeze
[email protected]
http://www.servicematters.com/maytag_library/docs/SAM0074.pdf
Anonymous
  • 1922 Answers
  • Posted on Nov 02, 2009
SOURCE: Frigidair Gallery fridge/freezer... Freezer is
change the control board in the rear lower left corner of unit part# 4334000 2 appliance parts pros
Anonymous
  • 43501 Answers
  • Posted on Sep 30, 2010
SOURCE: Refrigerator not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
jgjg
Directions how to use self cleaning over on the fridge re gallery gas stove
Hello, Joan -
Clarification: You are asking about a Frigidaire Gallery model gas stove and how to use the self-cleaning feature for the oven? If so . . .
You will find the instructions here:
https://www.hunker.com/12002208/instructions-for-a-frigidaire-gallery-series-self-cleaning-oven
If you need the user manual for your oven, you can add the model number by choosing Comment and adding the information there, so I or someone else volunteering to answer on Fixya.com can look for and provide the right link for a download of a free manual.
Note: There is more than one Frigidaire Gallery range model numbers made:
https://www.frigidaire.com/Kitchen-Appliances/Ranges/View-All/?filter=Feature02012:Feature02012
Best wishes.
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
Fridge started to make a humming Unplugged it,let it sit for an hour,it was fine.water on the floor from the ice-and I unplugged it for the night.I got up shook it-worked for 2 weeks.
What sort of "humming" noise? Refrigeration systems rely upon vapor compression to operate -- meaning occasionally to maintain temp a compressor will kick in which can hum.
I have a frigidaire model frs 22 zgh side by side fridge build up ice on the evaporator? or the defrost heater is not working?
hi
one of the sensor is not working
you need to unplugged it and leave it to defrost for 6 hours
in order to release the sensor arm
Frigidaire Gallery Professionaly series broken ice maker
If you hook up the water to the fridge, that means you connected the water line to the 'Water Inlet Valve' of the machine. There should be a two wire harness connected to the water valve back. Look for that....
But please note following...
Some water valves in fridges are complicated with one harness for water dispenser line valve and another harness for ice maker water line.
Also seeing a disconnected wire harness does not mean it is for the water valve. May be most likely. But be careful sometime there are test wire harness for technicians to get power readings for components.
1helpful
Frigidaire Gallery fridge, 1999. where is the water filter?
What is the model number of the refrigerator. looks like it is in the upper right corner of the fresh food section. If you go to frigidaire.com you can get the owners manual.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
