20 Most Recent Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Questions & Answers
Fliped the circut breaker and got the 3 blinking lights and hit start and it ran fine.
Frigidaire 24... | Answered on Jun 24, 2019
Hello Mileshjr,
I don't disagree... Nice looking unit...
What you have to do is assess the LEAK(s)...
and do a cost/benefit analysis...
If indeed the parts are available (they seem to be)
http://www.appliancepartspros.com/motor-pump-parts-for-frigidaire-fdb1050rec0.html
Then all you have to do is find the cause of the
LEAKS and repair them...
Mine turned to be rusted body panels...
(not much you can do there... Unless you
find a complete DONOR... Not unlike restoring cars...
(the labor of love)...
Check out other part houses...
Repair-clinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Part-Select
PartSelect Appliance Parts and Repair Help
... and don't forget to check eBay.
I will confess the new PRO Series "QUIET" models
are VERY quiet... and sooo... pretty I had to REMODEL
the ENTIRE KITCHEN... (no savings there).
Hope this saves $$$$
Carnac the Magnificent
Frigidaire 24... | Answered on Mar 15, 2019
petroleum jelly rubbed on the nylon cord and all parts that it touches...it does the trick
Frigidaire 24... | Answered on Sep 22, 2018
If the cycle does not run I say the timer is in need of repair/replacement. Go to site for parts Search Over 2 1 Million Appliance Parts
Frigidaire 24... | Answered on Aug 29, 2017
nothing specific until you get a technician to properly diagnose the fault
Frigidaire 24... | Answered on Aug 19, 2017
The intake light blinking error can be caused by several different problems and may take some pains taking effort to figure it out. There is some helpful information about Intake/Drain light flashing. http://www.techanswerslive.com/appliances/miele-icognito-dishwasher-service-mode-error-codes/12
Frigidaire 24... | Answered on Nov 16, 2015
That gasket is supposed to look like that. Use less soap and/or replace that gasket. It is very easy to do but pay attention to how the old on is placed. There is a small notch that has to be placed right.
Frigidaire 24... | Answered on Feb 08, 2015
Good Morning Friend,
I understand your Frigidaire dishwasher, model# FBD1050REC, will start on delay start but not just by pressing the start button. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Frigidaire 24... | Answered on Jan 24, 2015
Hello friend, thanks for your inquiry!
On your Frigidaire dishwasher "i30" stands for aqua control. You should perform a reset on your dishwasher and that could clear any false error codes. To reset your dishwasher you can flip the household circuit breaker off for ten minutes. If that does not work you could be experiencing an issue with your water inlet valve or control panel. I hope this information has been helpful. -Matt
Frigidaire 24... | Answered on Oct 16, 2014
hi there,
check the door latch and door handle to make sure that there is nothing broken or bent. otherwise, you have to replace the door locking mechanism.
Frigidaire 24... | Answered on Aug 14, 2014
Good Afternoon Friend,
I understand your Frigidaire dishwasher, model# FDB1050REC, is not drying your dishes. I also see you want to know which part needs to be replaced. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose and determine what exactly is causing your appliance to not dry the dishes. Hope this is helpful.
-Best Regards-
WP
Frigidaire 24... | Answered on Jul 08, 2014
I understand you are replacing the soap dispenser in your Frigidaire dishwasher, model# FDB1050REC, and want to know how to access the screws to remove front panel of the door. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals for this repair. I suggest contacting your local authorized technician for further assistance. I hope this is helpful.
-Best Regards-
WP
Frigidaire 24... | Answered on Jun 23, 2014
I understand that your Frigidaire dishwasher, model# FDBB4365FC0, will not drain. I also see that you do not have a manual. Try these troubleshooting tips below.
    1)If your appliance is hooked up to a garbage disposal, make sure the disposal is empty.
    2)Make sure the knockout plug has been removed from inside the garbage disposal.
    3)Check to see if the drain hose is kinked.
    4)Make sure the cycle is complete and not in pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Frigidaire 24... | Answered on Jun 12, 2014
I understand that your Frigidaire dishwasher, model# FDB4315LFC2, starts and then stops, and flashes a "PF" code when it stops. The "PF" code is stating that there has been a power failure. There could be a possibility that your dishwasher is losing power mid-cycle. I suggest checking your home's circuit breaker, the wiring to your dishwasher, and if you have a cut-off switch, checking that as well. I also suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 20-30 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
569 questions posted
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Vitally Alcher
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Dishwashers
Most Popular Question
i30 error code frigidaire dishwasher
  • Dishwashers
