Canon PowerShot A300 Digital Camera Logo
Posted on Jul 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I TURN OFF the date/time stamp? It is easy
How do I TURN OFF the date/time stamp? It is easy to set, but there is no way to turn it off. (PowerShot A2000 IS).
Anonymous
Level 2:
  • Expert 153 Answers
  • Posted on Jul 25, 2009
Anonymous
Expert
Level 2:
Answers
153
Questions
0
Helped
41574
Points
362
Well please check the setting in your  camera then set them and turn it off and try again.
Is it possible to stamp date and time on pictures using a kodak cd82 camera?
To set the date and time on your camera, follow these steps:
Turn on the camera and set the language and date/time by following the instructions in the Extended User Manual.
Once you have set the date and time, you can turn on the Date Stamp feature by following the instructions in the User Manual . The date and time will be stamped on all pictures taken with this feature enabled.
KODAK CD82 - EXTENDED GUIDE EXTENDED USER MANUAL Pdf Download ' ManualsLib
KODAK EASYSHARE CD82 USER MANUAL Pdf Download ' ManualsLib
Turn off the date stamp
You didn't give the model number of your Coolpix, so I can only give you general instructions. Explore your camera's menu. Somewhere, you will find an item that will allow you to turn the date stamp on or off and set the current date and possibly the time.
Date stamp coolpix s9050
If you want a date stamp on photos go to Menu and turn on Date stamp after setting proper date under time and date setting under Menu. Rich
6helpful
Need to email pictures showing the date and time stamp on panasonic dmc fh27
Turn on the [Date Stamp] setting in the [Rec] menu. See page 83 of this manual.
2helpful
How do i change the date stamp on my camera? Kodak Easy Share m1093
  • Turn the Kodak's dial to "Capture" mode. This brings up the camera display. Press the "Program" button behind the dial.
  • 2
    Press the "Down" button until "Date Stamp" is highlighted. Press the "OK" or "Set" button to access the date-stamp menu.
  • 3
    Press the "Down" button to change the selection to "None." This removes the date stamp.
  • 4
    Press "OK" to save the setting. Press "Program" to return to capture mode.
  • 6helpful
    How do I turn off the date and time stamp on my canon powershot sx110?
    The menu on the camera controls the date and time stamp. Turn on the menu i camera mode, there are three choices, Camera, Settings and customize. Time stamp should be in the middle menu. Look for time settings and turn it off. All pictures have time and date always. The time/date stamp just makes it visible in the image.
    16helpful
    I CAN'T GET THE DATE TO TURN ON. IT WILL LET ME RESET IT, BUT IT WON'T LET ME TURN IT ON. When I go into the menu setting, it shows that the date is turned off and I can not access another menu that will...
    The date/time stamp only works in "Postcard" resolution. Press the "Func Set" button, then scroll down to the bottom to select postcard resolution.
    Then press the menu button. Select the "Camera" menu, then scroll down to the the Date Time Stamp selection to turn it on.
    7helpful
    Cannot turn on date stamp
    The date stamp only works in "Postcard" resolution. Press the Func Set button, then scroll down to the bottom to select postcard resolution.
    Then press the menu button. The date time stamp selection should now work. Simply turn it on.
    10helpful
    Date time stamp
    The camera must be set in the Postcard mode under the resolution setting (L, M1, M2, M3, S, Postcard) on the function menu. Press Function, scroll down to bottom, then scroll to the Postcard mode and press the Set button.
    8helpful
    Cannot turn date stamp on in menu settings.
    Date stamp is only possible when you set the resolution (picture size) at "Postcard 1600x1200" option, if the date stamp is set to "Date & Time" or "Date" option
    Top Canon Cameras Experts
    old marine
    old marine
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Canon Camera Expert? Answer questions, earn points and help others
