20 Most Recent Canon PowerShot A75 Digital Camera Questions & Answers
Display went purple with lines then finally died this year, contacted Canon at the link below and they paid all shipping (both ways) in less than 10 days I have the camera back and working like new for $0.00, these guys care about their products and customers. If you have this issue contact them and they will handle it right.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=9828
Canon PowerShot... | Answered on Jul 11, 2019
work for about 50% of lens errors, but they're worth a try. The list includes:
  1. Remove the batteries and wait a few minutes
  2. Try pressing and holding the Menu, Function, Function Set, or OK while turning on the camera, or otherwise find a "factory reset" option.
  3. Try turning the camera on without a memory card inserted
  4. Place the camera flat on its back and turn it on while holding down the autofocus button, to try to cause the camera to attempt autofocus while the lens is extending
  5. Blow compressed air in any gaps around the lens - or use a shop vac
  6. Use a thin piece of paper or a needle to dislodge any visible bits of grit
  7. Gently tap the camera in an attempt to realign jammed mechanics or dislodge particles (obvious warning: could cause further damage)
  8. Gently push or pull the lens barrel, as a last resort (again, potential for further damage).
Canon PowerShot... | Answered on Dec 02, 2017
More likely one of the spring contacts in the camera that connect to the SD card has become weak causing the problem.
Canon PowerShot... | Answered on Oct 31, 2017
For someone who has little knowledge on computer like me, I usually prefer to getting help with some pro programs, such as asoftech recovery program http://www.asoftech.com/apr/
or u can visit http://www.asoftech.com/recover/ where I find many guides in detail there.
Hope it can help u. Good luck.
Canon PowerShot... | Answered on Jan 09, 2017
Hi british gas will take nothing over 10 years on a contract so don't worry about that there plenty of gas fitters who will bo repiars on i,t hot water should be on for how much you are going to use 2hours in the morning longer in the evening its how much you will use too how long you have it on
Canon PowerShot... | Answered on Mar 14, 2016
Usually it's because the battery is getting low. Cameras will often shut down to prevent losing data. Make sure the battery is fully charged or the camera is plugged in if it has an external power adapter.
Canon PowerShot... | Answered on Nov 25, 2014
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Canon PowerShot... | Answered on Jul 06, 2014
Canon PowerShot A75 Digital Camera Logo
992 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
manual cannon powershot sx510hs lost
  • Cameras
