20 Most Recent Canon PowerShot SD1300 IS IXUS 105 Digital Camera Questions & Answers
2answers
Black fuzzy spot in pictures
Have you verified that it is in the picture and not the screen by transferring the photos to your computer?You way have some dust or lint that got on the lens if the photos have that problem.Just take an eyeglass cloth and spray wither eyeglass cleaner, or just a little dab of alcohol and then wipe the lens clean.
8/19/2022 2:26:16 AM • Canon PowerShot... • Answered on Aug 19, 2022
When I take a video
i dont think this will help but i have a kodak digital camera and when i do video i get no sound when i play it back. if you plug it into computer to download pics and video there will be sound with the video. thats how mine works anyway.. good luck..
11/27/2019 12:52:43 PM • Canon PowerShot... • Answered on Nov 27, 2019
6answers
I have a lens error on my canon powershot sd1300
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
10/1/2019 3:39:24 AM • Canon PowerShot... • Answered on Oct 01, 2019
2answers
Canon Ixus 105 lens fail restart camera
This is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you.
8/13/2017 8:49:50 AM • Canon PowerShot... • Answered on Aug 13, 2017
Canon SD1300IS memory card is locked. I have used this card for 3 years I don't get it?
Possibly data is corrupted - format card in the camera
7/5/2017 4:49:00 PM • Canon PowerShot... • Answered on Jul 05, 2017
I have a cannon camera, my boyfriend dropped it with the lens extended and now whenever I try to turn it on I get a message saying that there is a lens error and the camera will shut down. I have trie
Those lenses have very small gears and motors. It would be best if you sent it in for repairs. WWW.unitedcamera.com
5/22/2017 11:17:47 PM • Canon PowerShot... • Answered on May 22, 2017
My digital camera error message
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101;'
1/14/2015 8:15:41 AM • Canon PowerShot... • Answered on Jan 14, 2015
My canon sd1300 lens wont open
fixing lens error in a digital camera just watch the video.
11/24/2014 1:09:59 AM • Canon PowerShot... • Answered on Nov 24, 2014
I dont know what is
Rechargeable batteries can and do just die without warning.Sometimes the charger does so as well. The charger automatically prevents overcharging though.
Realistically, all you can do at short notice is to try another freshly charged NB-6L battery. if a camera shop has a display model they might allow you to try their battery in your camera, or more likely, your freshly charged battery in their camera.
11/11/2014 9:02:43 PM • Canon PowerShot... • Answered on Nov 11, 2014
0answers
Remove time date picture
Try to use menu and settings. Also, date stamp can be used only in very low resolution images, change your image resolution and quality back to this large/superfine setting. And you can find the information related to date stamp in user guides. Look for them here Canon Camera user guides and owners manual
1/23/2014 11:51:54 AM • Canon PowerShot... • Answered on Jan 23, 2014
7answers
How to retrieve deleted pictures
You can recover deleted pictures with digital picture recovery software like asoftech photo recovery, download from link belowDigital Picture Recovery SoftwareYou can refer to this video tutorial
1/15/2014 1:15:06 AM • Canon PowerShot... • Answered on Jan 15, 2014
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
241 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
flash problems
  • Cameras
