20 Most Recent
Kodak EASYSHARE M1063 Digital Camera Questions & Answers
.mov file not recognized
hi,May be your mov file is corrupted; to repair it back, just use file repair software. Few days before, i was also suffering from the same problem. This tool has helped me to
repair mov file and i got all my precious videos back. Try this, it will surely give you positive result.
How do i charge my kodak 8.0 digital camera
What model Kodak 8.0 megapixel camera? The M1063 is a 10 megapixel model.
Some Kodak cameras can charge the battery when you connect the camera to a power source. Some Kodak cameras come with a separate battery charger. Some Kodak cameras use disposable batteries. Without knowing the model of your camera I can't tell you how to charge your camera.
Kodak digital camera not charging/ indicator not
Either an error occurred during charging, an AC power disruption occurred during charging, the wrong AC power adapter is being used, batteries are over- discharged, batteries are defective, or no batteries are installed in the camera.
Try charging the batteries a couple of times. If that fails, try charging the batteries in an external charger. If the batteries still will not charge, purchase new batteries and try again
I can't see LCD screen on my camera when I'm outside
Look under settings and turn up the brightness. Being a camera it probably has no way of adjusting to the bright light outdoors. I think only newer "sports" models would even be able to do so. Crank it to maximum. It still may be hard to see.
Kodak Easyshare M1063. Picture transfer.
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Kodak m1063 not holding date and time
There is an internal battery in most cameras that is charged by the Lithium Ion battery when the camera is in use. If the camera is being used and the Lithium Ion battery is fully charged and yet the time/date is not being stored then there is probably a problem with the internal battery
