20 Most Recent Canon PowerShot SX100 IS Digital Camera Questions & Answers
Does the auto exposure go down to 30 secs? If you are getting 30 secs on B mode then the self timer will not work. Set the camera to full auto and then from the menu select self timer, you should have 2 options 2 sec and 10 sec. Then press the shutter
Canon PowerShot... | Answered on Sep 24, 2019
Think it is a file issue where the file you have copied to disk is not compatible with what your player can handle. Trick is to convert the file into one that your player can read. Plenty of freeware around for that - just Google it.
Canon PowerShot... | Answered on Jun 28, 2017
This should be covered in the camera manual - it will probably be a menu setting.
Canon PowerShot... | Answered on May 23, 2016
The 20x optical zoom in Canon PowerShot SX10 makes it the winner. Find its features at http://www.tolmol.com/Canon-PowerShot-SX10-IS/blogposts/9251/76711
Canon PowerShot... | Answered on Sep 21, 2015
If you mean the battery for the time/date in you camera, it does not have a compartment for it, the battery that keeps the time/date is internal. It is usually a button cell like what a watch uses. To replace the memory battery requires to take the front and back panel off your camera, not an easy task. Most of the time it is easy and requires you to remove all the tiny screws around the camera, once you remove all the screws you can pry open both front and rear panels, you do have to hunt for that little button cell battery as every camera has it in a different location?
Canon PowerShot... | Answered on Feb 12, 2015
Camera shake? When you zoom and make things bigger, you also make movements bigger. So a relatively small movement could manifest as camera shake. Make sure your shutter speed is high enough.
Canon PowerShot... | Answered on Jan 23, 2015
hello friend, you can find the canon powershot sx100 service manual in below link
Canon SX100 IS service manual:
http://goo.gl/4VFvhd
thanks
Canon PowerShot... | Answered on Nov 27, 2014
My Canon Power Shot SX100 IS says lens error. restart camera. Help
Canon PowerShot... | Answered on Nov 07, 2014
hi
if you see lens error on back of lcd and lens barrel is stuck, then your camera would need replacement of zoom control gears or a whole lens unit. Either way your local repair shop would charge you almost same cost depend on time consume. the cost would be around $75 to 135 depend on what they realy want to charge.
Thanks and best regard!
I'm out of practice because my camera suddenly stopped working 6 months ago, but I don't recall having a problem with blurry pictures when I used the zoom. Sometimes, it takes a few seconds for a pic to come into clear focus. I think the trick is to just keep working with it.
Canon PowerShot... | Answered on Jun 21, 2014
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Canon PowerShot... | Answered on Apr 27, 2014
The best way to download pictures and videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures and videos from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto for pictures and iMovie for videos.
Canon PowerShot... | Answered on Feb 11, 2014
This is all I can do for you. Just sending a picture of the battery door spring from my PowerShot G9. I think Canon uses the same principle more than once. I hope this can help. 0544a321-ab53-4e6c-8c99-9fab3dd0040d.jpg
Canon PowerShot... | Answered on Jan 19, 2014
Canon PowerShot SX100 IS Digital Camera Logo
482 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
problem copying videos
  • Cameras
