20 Most Recent Canon PowerShot A620 Digital Camera Questions & Answers
If it's still under warranty, go to Canon's website and arrange for a repair.
Canon PowerShot... | Answered on Oct 31, 2017
SD and micro sd are standard sizes you cannot get the wrong size
Canon PowerShot... | Answered on Jun 08, 2015
Check your new memory card in a computer, using a memory card reader (they ares cheap), Should open jut like a pendrive, as removable disk..
If won't open, your new card is bad.
eBay, Walmart, Target, Best Buy
Canon PowerShot... | Answered on Aug 31, 2014
PowerShot A620 supports up to 4Gig
Canon PowerShot... | Answered on Aug 23, 2014
Thomas,
You will find a small knob on the card which makes it write protect. If the issue persist try any other card.
Canon PowerShot... | Answered on Feb 27, 2014
Has the card been "protected" with the sliding switch on the side? This would prevent any writing to the card.
Hope this helps
Canon PowerShot... | Answered on Oct 25, 2013
What type and size memory card? The A620 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Canon PowerShot... | Answered on May 29, 2013
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the above didn't work, then consider the following:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Canon PowerShot... | Answered on Nov 30, 2012
Thanks for the tip that was actually not listed in the the user manual.
This morning I encountered my slightly over one month (Dec 2013) old Keurig Mini B31 jammed up, I was only used 3 times so far...:( and feeling quite frustrated after wasted all 3 K-cups to try and find out what went wrong, initially thought it did not punch the hold properly, but still only a few drops of coffee came out from the brew, everything thing seems to work fine, it was just no hot water flowing down.
Tried to clean up K cup bottom needle with clip, but does not help, after browsing though fixya found that the top part needle also really need to clean up (not stated in the user manual), by using paper clips and finally it works again after all the dirt came out from the top part of hold puncher. My tips for people who did not use it daily /very often, they should:
  • Clean up the top needle by running through a cup of water to flow it through the ground coffee excess after each brew was completed, otherwise it will tend to dried up and choke up before you know it.
  • It help to shake it cup to have the top of the cup fill with some air, and it has less tendency to have the ground coffee in block up the top needle.
Hope this tips will help you to maintain a good cuppa!
Canon PowerShot... | Answered on Nov 25, 2012
No, you have to press the shutter release button to take the picture.
Press the FUNC/SET button. Use up/down to select Drive Mode (the rectangle, third item from the top). Use left/right to select the desired delay and press FUNC/SET. This sets the self-timer. Start the self-timer by pressing the shutter release button as usual.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Canon PowerShot A620 Digital Camera Logo
219 questions posted
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
trying buy new memory card will not work
  • Cameras
