I
Ian carr Posted on Sep 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice what to do to resolve. Thanks
darinthal
Level 2:
Novelist:
  • Canon Expert 181 Answers
  • Posted on Sep 10, 2014
darinthal
Canon Expert
Level 2:
Novelist:
Answers
181
Questions
Helped
51586
Points
361
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
I have changed all ink cartridges on my canon pixm - 6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "
Manual Print Head Alignment."
1helpful
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
1helpful
2answers
Canon i320 amber light flashing will not print
I believe that 7 amber flashes refer to a cartridge error. Check that the cartridge is seated correctly.
2answers
Error code 6A00
6A00 error on a Canon IP4200 is an AP Postion Error. This means one of three things. A problem with the sheet feeder, Logic board or the Purge Unit. Sadly these part are either working or not working and are difficult to repair. You could try resetting the EEPROM on the unit by entering service mode. A service manual will show you how to do that:
http://www.tradebit.com/filedetail.php/4593231-canon-pixma-ip4200-printer-service-manual
If that helps please rate my solution
2answers
Paper stops half way
Please check for torn piece in the carriage which is causing the error
4answers
CANON 1P4200 PRINTER
I would try a new ink tank. They do go bad even though they have ink in them.
Canon i865
Hi , to remove ink from ink mat , need to look for used injection cyrene , to suck up used ink , suck ink until no ink to take , just enject to mat reverse injection put in a clean jar , wear rubberized glove.
UNRECOGNIZABLE INK TANKS
Does this model have 'chips' on the tanks? Check for a reset option in the manual or trial and error by switching the machine off then on again whilst holdimg down one or more of the buttons For further help take a look at www.fixyourownprinter.com
2answers
Error message 6A00
AP position error [6A00] the Sheetfeed unit or the main logic board has failed need to purge unit. Give it a good tank cleaning, possibly replace cartridges. Is it still under warranty? Have you contacted Canon?
old marine
old marine
ZJ Limited
ZJ Limited
