20 Most Recent Canon BubbleJet i560 InkJet Printer Questions & Answers
2answers
Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
12/1/2021 6:03:49 PM • Canon BubbleJet... • Answered on Dec 01, 2021
Canon Bubble Jet i360
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
11/29/2018 8:48:55 AM • Canon BubbleJet... • Answered on Nov 29, 2018
MY HP psc 1310 is printing out blank sheets of
Some printers deny service even if there is only 1 cartrige empty.
9/3/2017 6:40:59 AM • Canon BubbleJet... • Answered on Sep 03, 2017
2answers
The waste ink well is full
Reset Procedures for Canon i560 Printers
  1. Turn off i560 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
  9. Please remember at some time of other you will need to clean out the ink pads that are inside the printer.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
8/13/2016 10:59:58 PM • Canon BubbleJet... • Answered on Aug 13, 2016
2answers
Canon i560 Black Ink Problems.
8/13/2016 2:43:57 PM • Canon BubbleJet... • Answered on Aug 13, 2016
2answers
Black not printing
Canon Bubble Jet i560 Ink Jet Printer not printing black
8/13/2016 2:41:45 PM • Canon BubbleJet... • Answered on Aug 13, 2016
2answers
My printer (Canon i560) is not printing cleanly.
spaces missing in the printed document
8/13/2016 2:39:30 PM • Canon BubbleJet... • Answered on Aug 13, 2016
My i560 canon printer goes through the print cycle, but it won't adhere the ink.
Canon printer not printing
8/13/2016 2:33:39 PM • Canon BubbleJet... • Answered on Aug 13, 2016
2answers
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
8/13/2016 1:54:21 AM • Canon BubbleJet... • Answered on Aug 13, 2016
Http www youtube com watch
Power on the machine, open the front hatch as if changing a cartridge. Remove all the cartridges, then lift the locking arm holding the print head in place. Remove the print head and wash under running warm water. Dry it with a soft paper towel and replace it and the cartridges in the printer. Close the hatch and wait for the machine to reset. Hold the resume button until the power light flashes twice - it will do a self clean and test print.
5/3/2016 12:43:15 AM • Canon BubbleJet... • Answered on May 03, 2016
How do I do a waste ink bypass to recycle ink from waste tank to avoid it getting full again?
There is a small tube running from the pump to the waste ink pads. If you connect another tube to that, you would be able to run it out to an external bottle. Please note this won't stop the waste ink counter from doing it's thing.
5/3/2016 12:36:18 AM • Canon BubbleJet... • Answered on May 03, 2016
Windows 7 wont recognise drivers
Your machine is probably too old for the OS. Try networking an XP machine with the printer as a shared unit on the XP PC.
5/3/2016 12:34:22 AM • Canon BubbleJet... • Answered on May 03, 2016
2answers
Canon i560 yellow light blinks 5 times. How do I
This is a printhead/cartridge error.
First try to reset the computer:
Resetting the PrinterBy resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur.Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
If that doesn't work try to reseat the printhead.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i560_series#ServiceAndSupport
3/13/2016 7:24:28 PM • Canon BubbleJet... • Answered on Mar 13, 2016
Won't print in colour
In the Printer Settings you have to leave it as '"Print in Color" always not Black even if you want to print B&W.
Good Luck
luciana44
4/7/2015 9:31:49 AM • Canon BubbleJet... • Answered on Apr 07, 2015
How do i empty waste ink tank on cnon i560 printer
You cannot do this yourself but you can google the problem and you should find a reset code that disables this warning, mine has been running for 12 months with this disabled
7/23/2014 7:19:10 AM • Canon BubbleJet... • Answered on Jul 23, 2014
Canon BubbleJet i560 InkJet Printer Logo
Popular Tags
418 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
BubbleJet Canon
  • BubbleJet Canon
Most Popular Question
waste ink bypass recycle ink from waste
  • Office Equipment & Supplies
