20 Most Recent Canon PIXMA iP4200 InkJet Photo Printer Questions & Answers
4answers
Error code 5C00, Canon Selphy DS810
HI..
It means that the purge assembly, thats the cleaning unit where the printhead parks when off on the right, is jammed and cannot move.Look for paper or foreign material stopping it from moving. Sometimes the squeegee unit needs to be pushed back if the pads get stuck under it...
thank u
rate me
11/21/2021 5:11:26 PM • Canon PIXMA... • Answered on Nov 21, 2021
Canon iPF8000s error code garo w 1234 keeps coming up - why? how do i fix it
seems like one of printer cartages are bad
10/6/2021 2:05:46 PM • Canon PIXMA... • Answered on Oct 06, 2021
Error 1660 on Canon ip4200
Canon Support Code 1660 shows a cartridge error. It normally happens when you do not install ink cartridges correctly into the printer. As and when it shows error 1660 with your Canon machine, you will not be able to take the printing session more. Moreover, you will notice that the printing method becomes slow and sluggish. Reasons that cause Canon Support Code 1660. 1. Ink cartridges are not installed properly. 2. Printers are unable to recognize the ink tank. 3. Inks cartridge may be damaged or clogged. 4. Misplacement of ink cartridges. Don't get fear if you are also suffering the same position, you can easily fix this error by taking help from us. Full Blog - Canon Support Code 1660 printer-support-3-undefined-undefined-2_17.jpg
8/23/2020 3:48:19 PM • Canon PIXMA... • Answered on Aug 23, 2020
Error 5B00 and don't know how to fix it.
Error 5B00 refers to the waste ink absorption pads.
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates error 5B00.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
1/22/2019 4:38:02 PM • Canon PIXMA... • Answered on Jan 22, 2019
3answers
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
11/15/2018 8:58:10 PM • Canon PIXMA... • Answered on Nov 15, 2018
Service error 6500 (orange light flashes 20 times)
Orange light flashes 20 times - Light Office
3/20/2018 6:40:20 PM • Canon PIXMA... • Answered on Mar 20, 2018
I have a canon pixma
no number but you might need to replace all the inks otherwise in windows set the print for grey scale (black and white only) and not color and see if it prints then
3/7/2018 4:08:07 AM • Canon PIXMA... • Answered on Mar 07, 2018
Alarm/power light blinks five consecutive times
A repeating 5 orange flash is supposed to mean a foreign object inside the machine interfering with the print head. Check at both ends or the carriage track for a crumpled up wedge of paper. If nothing is there, check down the back paper feed path. If still nothing, it is possible the print head is overheating and is about to die.
1/4/2018 8:32:40 PM • Canon PIXMA... • Answered on Jan 04, 2018
Canon PIXMA iP4200 not printing PGBK properly - only printing top 50% of PGBK grid on test page.
Man you did some awesome troubleshooting! I don't know, but it sounds like something is physically wrong with internal electronics. I'd call in the big dogs at Canon themselves. https://www.usa.canon.com/internet/portal/us/home/contactus
9/29/2017 5:08:20 AM • Canon PIXMA... • Answered on Sep 29, 2017
I'm trying to get my Canon iP4200 to print in BLACK ONLY
Hi . I think the print head may be is clogged. If cleaning didn't correct the problem . Print head need to be replaced
6/25/2017 11:17:52 PM • Canon PIXMA... • Answered on Jun 25, 2017
PIXMA 4200 RESET/OK Button
Ok/Resume button is the one in the middle If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
6/3/2017 4:56:27 AM • Canon PIXMA... • Answered on Jun 03, 2017
Canon pixma ip4200 not printing
hi. you need to replace the cartridge.
5/1/2017 2:14:03 AM • Canon PIXMA... • Answered on May 01, 2017
Canon ip4200 won't print - "Ink Tank Errors Have Occurred"
Try a new tank. Probably faulty
4/2/2017 8:48:41 PM • Canon PIXMA... • Answered on Apr 02, 2017
Hi there my printer Canon pixma
Any error code displayed on PC ?
2/10/2016 11:05:32 AM • Canon PIXMA... • Answered on Feb 10, 2016
4answers
Canon PIXMA iP4200 - not printing in colours
hi i am a Canon certified tech for this machine.the orignal problem you had most likely was not your printhead but since you washed it most likely it is ruined. the problem most likely is the purge unit. the purge unit is the unit to the far right of the machine. this unit cleans and purges ink from the ink tanks to the printhead. to do this it uses 2 pads one for black and one for color. these pads can be flushed with water to soften up any ink. i would also replace the printhead which can be ordered by calling 1-800-OK-CANON or by going to their website. one other tip, refilled ink cartridges cause more clogging of printheads and purge unit then OEM ink. this is because the ink is thicker then the OEM ink. hope this helps to clairify.
1/24/2016 8:38:06 PM • Canon PIXMA... • Answered on Jan 24, 2016
Why does it indicate ink cartridge is not Canon?
are you saying that the ink cartridge is not genuine canon many machines will report if a generic cartridge is used and some will not operate with a generic cartridge installed
10/11/2015 1:30:40 AM • Canon PIXMA... • Answered on Oct 11, 2015
2answers
Prints blank pages, no text
did u check ur ink lvl sir?
8/23/2015 5:00:50 AM • Canon PIXMA... • Answered on Aug 23, 2015
My printer prints only blue after replacing cartridges, what is the problem?
Hi, try doing a printer head cleaning procedure, available on the maintanance/ repair screen of the printer, then do a test pattern. If the problem is not resolved you will have to do a deep cycle head clean (which uses a lot of ink- as a last resort). All the best. Good luck.
3/13/2015 12:34:32 PM • Canon PIXMA... • Answered on Mar 13, 2015
Canon PIXMA iP4200 InkJet Photo Printer Logo
649 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
printer fails print says amp 39 t
  • Office Equipment & Supplies
