20 Most Recent Canon i80 InkJet Printer Questions & Answers
There is only one solution to the problem with the i80. Here it is: there is nothing jammed. This problem is the result of the top of the printer being pushed down, effectively crushing the paper feed path by a sixteenth of an inch, right at the center of the machine. Likely this is the result of being carried in a travel bag full of other stuff, like the power supply, or from things being placed to rest on top of the printer. The solution is to open the two top covers, to grasp the main steel bar that runs the entire width of the printer with a pair of long-nosed pliers and to simply apply upward pressure. This will, in turn, lift a black plastic paper guide that has been pushed down into the path of the paper by the slightly bent metal. The printer will happily feed paper after this relatively simple fix. Mark the problem up to bad industrial design (though the mechanisms of the printer are otherwise ingeniously well thought out).
Canon i80 InkJet... | Answered on Dec 05, 2013
look up the printer tray sir.... if you see a lots of paper inside the tray removed it.. then try again printing... or else... try to change the printer mother board...
Canon i80 InkJet... | Answered on Oct 24, 2013
Is it OEM? Some printers do not recognize off brands or refilled cartridges.
Canon i80 InkJet... | Answered on Jan 28, 2013
there is a take up sensor at the back of the paper tray. If that is broken off or damaged then the printer will think there is always a piece of paper in the carrier and generate the error.
with the cost of new printer today, you are better off going and buying a new one.
Dell has color laser printers for less than $300.00.
good luck.
Canon i80 InkJet... | Answered on Mar 31, 2012
http://www.ehow.com/how_6527399_fix-error-5100-canon-i860.html
plz click this link
and find the instruction how to remove this error
Canon i80 InkJet... | Answered on Dec 23, 2011
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts
Canon i80 InkJet... | Answered on Nov 30, 2011
1. Disconnect printer power cord
2. Open the printer cover
3. Press and holding power button connect power cord
4. Close cover and release power button (you are now in service mode)
5. Download and use to reset this tool
http://www.servicemanuals.ru/download/canon/ip1000st.zip
6. Unzip and remove read-only attributes from files Pattern.prn and EEPROMData.prn
7. If it did not recognize the printer on usb port - you must enter the port mannually (ex. USB017), info taken on printer properties.
8. VOTE as FixYa!!!!!!
Canon i80 InkJet... | Answered on Jul 31, 2011
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Canon i80 InkJet... | Answered on Jun 04, 2011
Hello and Welcome to FixYa!
If you are facing Error 5100 then it means that the cartridge can not be detected by the printer.
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve this error follow the given steps:-
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed.
I hope this solution helps you
Let me know If you have any more Confusion, questions or issue regarding your problem
Thank you and Keep using FixYa!
Canon i80 InkJet... | Answered on May 15, 2011
you dont need to immerse evrything just slide paint cleaner back and forth / side to side till your arm drops off, lol sorry its 4am do this for 5 mins, also if you have seen track marks in black in the past check it for old paint build up
Canon i80 InkJet... | Answered on Mar 06, 2011
Canon i80 InkJet Printer Logo
153 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon i80 printer wont feed paper
  • Office Equipment & Supplies
