1) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
4) When the Power LED lights in green (and "ServiceMode Idle" is displayed on the LCD), press the Stop/Reset button the specified number of time(s) according to the function listed in the table below, then press the ON/OFF button. (Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED
1) In the service mode, press the Stop/Reset button 4 times to enter the ink absorber counter resetting mode
2) In the ink absorber counter resetting mode, press the Stop/Reset button the specified number of time(s) according to the kind of ink absorber whose value should be reset to 0%.
SOURCE: waste ink full
This step is a "reset" step for the Canon CLI8
cartridges. The original Canon CLI8 cartridges have a memory chip on
the back of the cartridge, which sends a signal to the printer when the
cartridge is empty. Your printer won't be able to determine how much
ink is in the compatible cartridges, but you can easily monitor the ink
level by noticing the ink level drop in the cartridge as you print (the
cartridges are see-through), or by noticing low ink output on the
printed pages when you run out of ink. The "reset" procedure below is
the best procedure we know of to date to allow your printer to use
Uni-Kit cartridges which offer a tremendous savings over the Original
Canon products.
With the original chip now
attached to the compatible cartridge (you may need double sided tape to
get the chip to stick well to the cartridge), and with the cartridge
now in the printer, Press and hold the Reset/OK Button for 5 seconds to
reset the chips.
SOURCE: canon printer mp160 e27
how can i get my ink absorber to be unful and work agian so i can print again WANALI
SOURCE: E27 Waste ink absorber full
canon mm140 E27 = Waste ink absorber full or platen waste ink absorber full what would be made to solve this problem
SOURCE: E27 = Waste ink absorber full or platen waste ink absorber full
http://www.divshare.com/download/launch/996190-2fb
you can get your problem fix download reset software
Ip 1700/Ip 1300/ IP 1500
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
