20 Most Recent Canon SmartBase MP390 All-In-One InkJet Printer Questions & Answers
Cartridges were defective
PURCHASED NEW CARTRIDGE
Bitmeyen Kartu
Canon SmartBase... | Answered on Feb 19, 2014
You may download the manual from here.
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
You could try to reseat the printhead again.
Remove printhead, lower printhead lever, close cover.
Let printer to cycle to alarm condition.
Reinstall printhead.
Canon SmartBase... | Answered on Jan 11, 2011
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
Canon SmartBase... | Answered on Dec 15, 2010
Go to this site... the waste ink tank counter says it is full...<br /> <br /> <a href="http://www.fixyourownprinter.com/forums/printer/41386">http://www.fixyourownprinter.com/forums/printer/41386</a>
Canon SmartBase... | Answered on Aug 30, 2010
CANON printers "compute" the "fullness" of the waste-ink container, based on the number of pages printed, and the "density" of the ink on each page. So, this calculation has produced a "nearly full" prediction. Take the printer to a qualified technician.
They will empty the waste-ink container, and "reset" the electronics in the printer, back to "zero-per-cent-full".
Canon SmartBase... | Answered on Aug 05, 2010
Are they the manufacturer's new cartridges? Frequently refilled or non-branded cartridges will not be recognized; if so replace with new ink tanks from Canon. Otherwise pull out the ink tanks and reinsert them. They may not be fully seated. New cartridges may be required to replace a bad cartridge; talk to Canon about the warranty.
Power cycling the printer (on/off, pulling the power cord) may reset an error. Some printers need to be on when the power cord is removed from the unit and then the wall to do the reset.
The next thing is to check the printhead if it is removable. (There is a lever that locks the printhead on some printers - lift it up after removing the ink cartridges. You can then pull the printhead and clean it (lint-free cloths and bottled or distilled water). Wipe away from critical parts.) Finally a new printhead may help; otherwise the unit needs service.
I hope this helps.
Canon SmartBase... | Answered on Jul 23, 2010
Canon SmartBase MP390 All-In-One InkJet Printer Logo
Popular Tags
89 questions posted
Clive
Clive
old marine
old marine
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
no manual use
  • Office Equipment & Supplies
