I am trying to install my printer but I keep getting a message that says "The printer spooler service is not running". Can you please help me fix my problem? Thank you!
spooler service not working
How to fix printer spooler for HP 1018 printer
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
You have to need the printer expert's help for printer spooler service. Contact our professional printer setup services, expert, today and resolve your printer spooler issues at a time. You can also chat with a printer expert at any time.
Go to the website http://www.hp.com/in and download the printer driversfo 1018 printer
I got my problem solved help of this follwoing article please click below and follow there mentioned steps and get your problem
fixed.
Click here to open solved Solution for this problem Spooler not working (Solved)
http://www.techsupportall.com/print-spooler-is-not-running/
I am trying to install my printer but I keep getting a message that says "The printer spooler service is not...
SOURCE: Printer Spooler service!
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left sice of your computer screen
2)go to control pannel
3)click performance and maintainence
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
pls do rate the solution if helped. thanks.
Click on "Start, Run", type "services.msc"
On the right side of the services window, scroll down to "Print Spooler". Double-click it.
If startup type is "disabled", click the drop-down and set to "Automatic" and then click "Start". If already on automatic, click "Stop" to stop the service. Once stopped, click "Start" to restart the service.
Reboot and try again :)
Hope this helps - remember to rate!
SOURCE: HP Laser Jet 1018 printer problem
To start the service:
To make sure it is automatically turned on the next time you run your machine:
Note: You will need administrator privileges to run those steps.
i need hp laserjet 1018drivers
Ugly problem. I installed a all in one 200 MB driver from HP for my 1018. It worked a week. Now same trouble.
Printer spooler service unavailable
