20 Most Recent HP LaserJet 3055 All-In-One Printer Questions & Answers
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
HP LaserJet 3055... | Answered on Jul 05, 2019
PRINTER ERROR The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error 1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner.
HP LaserJet 3055... | Answered on Apr 15, 2019
OK, here is my debugged/tested solution.
I know your error refers to a different installer MSI file (CIOUM32.msi) but the installation component in your log file (ipm12.A4B24390_80AD_4BAF_B8FD_C670FE0DB586) is identical to the one that was giving me trouble as well (i.e. points to the same service/file). So it is definitely worth a shot to try this solution out as it will only take a few minutes.
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
HP LaserJet 3055... | Answered on Feb 24, 2019
Flatbed scanner is bad replace whole top half p/n q6502-60116 approx. $150 - $200
HP LaserJet 3055... | Answered on Jan 28, 2019
hp laserjet 3055 by scanner error 6
Solution: I found a very small piece of paper between the glass and the scanner housing. The lamp's seen that and sent the error message. Nobody find that little stucked paper and the "IT expert" sad: need to buy a new machine because he can't repair it. So, sometimes the solution is very easy just need some attention. :)
HP LaserJet 3055... | Answered on Sep 13, 2018
If you go in your user manual to page 241, it shows the following instructions on how to reset the printer to factory defaults. One important note is that you will lose EVERY stored piece of information including phone numbers and such.
To restore the factory-set defaults
1.
On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Service, and then press .
3. Use the < or the > button to select Restore defaults, and then press .
The all-in-one automatically restarts.
Hope this does it for you.
HP LaserJet 3055... | Answered on Jul 30, 2018
Sounds like the sensor arm in the ADF is stuck in open position. Lift the flap of ADF and see if the sensor arm moves freely.
HP LaserJet 3055... | Answered on Jun 15, 2018
Hi benkoh76: Here is your problem. Troubleshooting checklist Follow these steps when trying to solve a problem with the all-in-one. Step number Verification step Possible problems Solutions 1 Is the power on? When the all-in-one is connected to a grounded power source and is turned on, the control panel shows Hewlett-Packard with moving cursors indicating that the firmware code is loading, and the main motor rotates for approximately 45 to 60 seconds. When the firmware is done loading, Scanner bulb warming up might appear on the control-panel display, and the scan head moves back and forth for 10 to 15 seconds. If you lift the scanner cover, you will see that the scanner bulb is lit. Near the end of this time, the ADF motor turns on for about two seconds. No power as a result of a failed power source, cable, switch, or fuse. 1. Verify that the all-in-one is plugged in. 2. Verify that the power cable is functional and that the power switch is on. 3. Check the power source by plugging the all-in-one directly into the wall or into a different outlet. Motor does not start. 1. Verify that the all-in-one is plugged into a working electrical receptacle. 2. Verify that the print cartridge is installed correctly. Follow the instructions on the control panel to remove and replace the cartridge. 3. Verify that the top cover is closed. ADF motor does not start. Open the ADF cover and remove any orange shipping tape inside the ADF. Verify that the ADF connector is connected correctly to the scanner. If the ADF motor still does not rotate, replace the ADF. Scanner bulb does not light. If the scanner bulb does not light, verify that the wire-harness connectors from the scanner to the formatter are connected correctly. If the error persists, replace the following components one at a time until the problem is resolved: scanner assembly, formatter. Hope this helps
HP LaserJet 3055... | Answered on May 11, 2018
Sir/Madam
Unfortunately there's no troubleshoot with a 52 error. As it implies it's usually the scanner bad. It sits up top- under the top cover. It connects to the Formatted Board on the left side. and there's 2 connector s at the scanner itself.
So if Your HP Printer is Under warranty ( 12 Months ) Then I Suggest You Go To Official authorized HP shop for your HP Printer Problem and Troubleshoot or Go To Official HP Printer Website To Update HP Printer Software and Driver,Or You Update It From Official Below URL Link:
http://h30499.www3.hp.com/t5/Printers-LaserJet/HP-Laserjet-P2055d-error-message-quot-52-Scanner-Error-Turn-off/m-p/5905671#M207987
or
Or
In Case You Having Still Problem Then Follow Us On:
HP Printer Support
HP LaserJet 3055... | Answered on May 02, 2018
The stepper motor controlling the scan arm is defective. Replace motor or entire unit.
HP LaserJet 3055... | Answered on Nov 15, 2017
Fat bed lid should be clean and closed, Scanner assy should move and scanner bulb should glow for a while, during the booting process.
The Flexible Flat Cable (pitch 1 mm x 30 Pin) should not be damaged (replace if damaged) and well pushed inside its jack in the formatter. (Open the right side cover and check).
The flat bed scanner's glass frame & Door base should mate perfectly with ease. If opened earlier, the ADF wire harness which passes on the inside along the rear right corner, can prevent PERFECT mating (if in palce the mating would not need any pressure and would fit in place easily), A gap of less tahn 1 mm can be the culprit.
If problem still persists open the scanner flat bed cover, clean the guide rod, check the laser assy movement, clean the black stripe above the resting place of the laser unit, laser unit mirrors ( 4 nos - with lint free fabric and Iso=Propyal Alcohol) re-assemble the flat bed cover with laser assy mid way on its path (to check movement when you boot). Ensure perfect mating as above stated.
If problem persists I fear you may have to replace the scanner assy or the formatter. Before you decide to replace formatter try "Permanent Storage Init" process posted by me for PC scanner "No connection" error.
GOOD LUCK
Sensor flag would have got stuck, check adf paper presence sensor
HP LaserJet 3055... | Answered on Oct 10, 2017
Clean rollers in the ADF (automatic document feeder) with methylated alcohol for quick fix or replace the roller assembly
PN: 5851-2559 and seperation pad PN: Q2665-60125
HP LaserJet 3055... | Answered on Aug 21, 2017
I assume the printer is not showing any errors on the control panel ? If so , that has to be resolved first. If not will it make a copy ?
PC or MAC ? What version of OS ? Is it supported ?
Once you determine that , uninstall any current software and/or drivers . Download the latest version , follow the read me instructions to install properly .
HP LaserJet 3055... | Answered on Jul 19, 2017
HP LaserJet 3055 All-In-One Printer Logo
761 questions posted
Ekse
Thomas F. Schneider
View Most Popular
LaserJet HP
  • LaserJet HP
Most Popular Question
hp lajerjet 3052 scanner error 3
  • Office Equipment & Supplies
