20 Most Recent
HP DeskJet 5550 InkJet Printer Questions & Answers
There is no icon on
The HP Toolbox can be used to check ink Levels
Right-click the taskbar printer icon .
Click Open HP Deskjet 5550 Series Toolbox .
Click the Estimated Ink Level tab.
- Check ink levels (estimate only, actual ink levels may vary)
Blinking/flashing lights(orange & green) &
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head
install both cartridges on ur printer n check ur blinking light on ur printer
that will work only if u r too lucky other wise u have to purchase a one cartridge.
HP Deskjet 5550 cartridge carriage stuck SPAM SPAM SPAM 1-800-532-4187
I have had this same problem a few times, not due to changing the cartiges, but following one of my kids yanking on a peice of paper as it was printing. After I tried all the unplugging and clearing and re-starting, the arm was still stuck on the left. I read on some forum (can't remember where) while the printer is off, to gently push/pull on the cartiges until they un-jam or start to move. I flet like I was going to break it, but it has worked every time.
Hope this helps osmeone else!
HP deskjet 5550 will not print. Flashing orange
Make sure the covers are closed completly. It will not print unless its closed. If its not that, then check to make sure you didn't knock one of the cables loose inside the printer, and make sure the belt that moves the cartridges is still intact and is not jammed.
Hhp deskjet 5550 - orange and green light keep
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button.
(Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button.
(Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times. Finally press the Power button.
Paper Mismatch
I had this problem on the 6300 and was able to fix it by doing the following:
After selecting print, select preferences.
Select the Features tab.
Under Resizing Options, select "Custom" from the drop down menu.
Put in the custom dimensions of the paper on which you are printing.
Save it under a new name (e.g., "Invitation")
When it is time to print,
Select "More" from the drop down tab under Resizing Options.
At the bottom of the list of those options, you will see your custom sized saved.
Select it, and happy printing.
