20 Most Recent HP OfficeJet 4215 All-In-One InkJet Printer Questions & Answers
HP 4215 All in One - check right cartridge error
Hello! As the manual of this device says Check the print cartridge to make sure you have properly removed its packaging. Being careful not to touch the gold-colored contacts or ink nozzles, make sure you have gently pulled the pink tab to remove the plastic tape. Here is the link to a manual of this device. Hopefully, it will help. http://manualsbrain.com/en/manuals/1174050/?page=154
7/25/2021 7:05:56 PM • HP OfficeJet... • Answered on Jul 25, 2021
My HP 4215 is saying paper jam, but there's no
there is dirt or paper covering the sensor inside, you should be able to easily take out once of the long tubes to clear this.
7/25/2021 6:54:31 PM • HP OfficeJet... • Answered on Jul 25, 2021
False paper jam message
you could try this link might help you out... False paper jam message Google Search
10/21/2017 12:19:17 PM • HP OfficeJet... • Answered on Oct 21, 2017
Repalcing the ink cartridges
Here is a link to the Setup guide to follow.
4215 Setup Guide
3/23/2017 11:55:25 PM • HP OfficeJet... • Answered on Mar 23, 2017
0answers
Model 4215 all in one printer. How can I reset?
http://www.hp.com/ctg/Manual/c00095626.pdf
8/12/2016 9:35:15 PM • HP OfficeJet... • Answered on Aug 12, 2016
It will print on typing paper but not on photo paper, says there is a paper jam
it says that it is an ink jet printer. did you set the paper controls to the right paper you are using. is the paper HP paper some of the papers don't work with the HP printers they may be to smooth and the rollers can't get the paper into where it needs to be for the sensors to say that there is paper present it has to hit the sensor within a specified time to work correctly.
1/28/2016 4:00:58 AM • HP OfficeJet... • Answered on Jan 28, 2016
Won't print documents and says OPEN DOOR
Try opening and closing the Print-carriage access door and the Rear cleanout door. This may reset the status. http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
9/3/2015 1:52:07 PM • HP OfficeJet... • Answered on Sep 03, 2015
I need Help fixing my HP Officejet 4215 All in One it keeps saying Cartridge Error and wont let me print anything.
Try reinstalling the printer drivers and software and plug connecting to the pc too
If problem still persist
There may be a problem in the cartridges holder
Then you have to connect with the customer care of the printer.
Or have to buy new printer easily and cheap at ebay
8/29/2015 6:15:52 AM • HP OfficeJet... • Answered on Aug 29, 2015
0answers
How to update my driver for hp 4215 officejet all in one
Go to HP.com.. select Support from the main screen. It will ask you to enter the electronic device you have, and then the model number, etc. Then you will have a list of options including firmware/driver updates including instructions on how to update your printer. You can also try to do it from Google on search entering 'HP Printer 4215 firmware update'. I would not trust any driver update that does not come directly from HP.
7/28/2014 10:34:40 PM • HP OfficeJet... • Answered on Jul 28, 2014
How to install my printer?
Can you confirm that it's an HP OfficeJet 4215 printer? What OS and type of device (computer, phone, Mac, PC, Windows version, ...) are you trying to install it on? How are you trying to install the printer? How are you connecting the printer to your computer? (USB, network, Bluetooth, Ethernet, or ?) Have you tried to install it, and if so, what happened? Exactly what error messages did you get? Here is a link to the drivers for the HP OfficeJet 4215 all-in-one if that helps you get what you need without answering all the questions above: Drivers Software
7/28/2014 9:46:32 PM • HP OfficeJet... • Answered on Jul 28, 2014
Off the hook
A "Phone Off Hook" message is not an error. It simply indicates that a telephone receiver isoff the hook(the handset is lifted) and the telephone line is open. This message would be expected in the following situations:
  • A modem on the phone line is accessing the Internet.
  • A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.
  • A credit card machine is using the phone line.
  • Another electronic device is using the phone line.
  • The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.
When the other device is no longer using the phone line, the display should revert to the normal message. Lets try the following, Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable. if issue still exists try the followign Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system. Hope It's resolve all Your Printer Problem, Or Still having Problem Then follow Us For HP Support
4/22/2014 8:31:01 PM • HP OfficeJet... • Answered on Apr 22, 2014
2answers
Replacement Black 27 for C8727A
This means its not a true HP cartridge.... All HP Printers have this problem. It really means that you have to go and buy true HP cartridge's . Sorry, but i hope this helps.
4/22/2014 6:50:14 PM • HP OfficeJet... • Answered on Apr 22, 2014
4answers
Scan using the HP OfficeJet 4215 Printer
The problem is with Windows Vista...it does not recognize the scan button when you touch it on the scanner. There are two ways around this:
Go to Programs / Windows Fax & Scan / Click new scan / click file and then click scan
OR
Go to Accessories / Paint / Cick File /click from scanner or camera / click scan
3/5/2014 6:53:01 PM • HP OfficeJet... • Answered on Mar 05, 2014
When downloading drivers from HP's website it is important to remember one thing!You MUST turn off any anti-virus software that you have on your PC/Laptop. If you don't they will not be downloaded correctly.If you don't the drivers will not be downloaded correctly and you will continue to have issues.
10/23/2013 4:34:09 PM • HP OfficeJet... • Answered on Oct 23, 2013
HP OfficeJet 4215 All-In-One InkJet Printer Logo
311 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
hp officejet 4215 all in one upgrated
  • Office Equipment & Supplies
