Canon Pixma Mp250 Allinone Inkjet Photo Laser Printer Logo
Posted on Aug 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The printer prints uneven lines and wavy lines
Anonymous
Level 2:
  • Expert 310 Answers
  • Posted on Aug 27, 2011
Anonymous
Expert
Level 2:
Answers
310
Questions
0
Helped
139172
Points
690
Your cartridge might be over flow/blocked by dirty inks... Remove your cartridge and rub the Cartridge head with toilet paper/soft paper neatly and replace again.... thanks
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
1helpful
2answers
Dell 3110cn - getting grey tint and wavy lines
It sounds like you have leaky toner or the imaging drum needs to be replaced.
1helpful
Printing wavy letters instead of straight
we have similar problem. my printer is canon mp 145. straight lines become wavy and some letters are italics when printed out. it was corrected when i used print head alignment but that was true when printing from my computer and not when using the copier. when using the copier lines still comes out wavy and i cannot correct it until now. please post when you solve your problem. i hope it will help you and i hope you can help me
It prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways. The printer seems fine and...
it prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways.
Canon MP510 prints uneven lines.
I assume that you've cleaned the nozzles and alignment utility.  Try wiping the carriage bar with a lint free cloth dampened with rubbing alcohol. Also, the paper feed rollers may have collected some "goo" and should be cleaned with the rubbing alcohol. This should clear the problem.
Cartridge Printing Problems Creating Wavy Line in Excel RFeport
Put a couple drops of oil on the shaft that the cartridges ride on.
The letters of the document when printed are wavy
Have you tried copying on the printer, will it also print wavy as well?
Because if you can copy fine and you cannot print properly using your printer it might be your computer. Why not use another application or program on your computer. In that case you can compare which has the issue.
Program such as MS Word, Powerpoint, Paint, Photoshop, etc
1helpful
Tally t6045 printing problem
hi!
there is two reasons behind this problem.
1. The parallel cable is damaged .
2.The parallel port of your computer is damaged.
so at first changed the parallel cable .if not solved connect your printer to another pc.
i hope the solution will work for u.
Regards
Swarnava Palit
U can mail me your problem- [email protected]
Uneven printing
Use the maintenance program to do a
"deep" cleaning
old marine
old marine
ZJ Limited
ZJ Limited
