20 Most Recent Dell 3110cn Laser Printer Questions & Answers
2answers
My dell 3110cn printer is
This error message indicates that the printer has failed to read information from the chip on the black printer cartridge.
This is either.
1. Black cartridge not fully pushed into place (I've been called out to a couple like this)
2. Faulty chip on the black cartridge - effectively not responding to the printer 'talking' to it.
3. Fault on the main board of the printer.
Solution
1. Push the cartridge fully home.
2,3. If you have an old black cartridge, try that. The message should change to Replace Toner, if it does, its the chip on the cartridge, if it doesn't its the printer.
2/9/2022 3:34:05 AM • Dell 3110cn... • Answered on Feb 09, 2022
2answers
Load Tray 1 Error Code: 024-965
you are using a wrong paper type setting, whenever in your "MS office" or "pdf reader" or othersif your printer uses letter, just set paper type as "letter" where you print the document, that should work.
2/9/2022 3:33:56 AM • Dell 3110cn... • Answered on Feb 09, 2022
My dell laser printer 3110 gives me two error
I fixed my 016-302 by replacing the network cables.
2/9/2022 12:16:00 AM • Dell 3110cn... • Answered on Feb 09, 2022
Dell 3110 laserjet printer, belt
This message is displayed when the pagecount of the transfer belt is 80,000 (ish)+. The rated life of the transfer belt in the Dell 3110/3115 is 100,000 pages. After that pagecount the transfer belt 'expires' and no further printing is possible until the transfer belt is replaced.
11/5/2019 6:23:15 AM • Dell 3110cn... • Answered on Nov 05, 2019
Check k cartridge 093-922
Could be
Bad chip on the cartridge
Some toner on chip contacts
Chip NOT been replaced (if its an remanufactured cartridge)
10/31/2019 10:37:44 AM • Dell 3110cn... • Answered on Oct 31, 2019
Has a code 016-302 and will not work
This error is almost always caused by a corrupt print job or driver. If the machine was working fine it may be as simple as canceling the print job and restarting everything (computer and printer).
Before sending the job to print again, it would be worthwhile to print a test page. If you can, you know the issue is specific to whatever you're trying to print. If you cannot, you know it's a most likely a driver issue.
Other possibilities:
- a recent OS update/upgrade killed the driver. This happened to a fair number of Windows 8 users.
-You're attempting to print from MAC but don't have the printer/driver setup for postscript. Weird but true, even in 2015 PCs and MACS still use different protocols to print to laser printers. (Not an issue for ink jets)
If this is the issue, here are the directions to setup the printer and MAC to work on your network. Notice the printer (wireless or not) should be wired for config-
PRINTER SETUP:
(1) Connect printer to the ethernet port
(2) On the controler of the printer, select menu
(3) with the cursors (down) select Admin Menu, and press ok (the center key)
(4) the text "wired network" will appear. Press OK
(5) Move the coursor down to tcp/ip. Press ok
(6) "get IP address" will appear. Press ok
(7) select panel. Press ok
(8) press "menu" and repeat (1) to (5)
(9) "get IP address" will appear. Move the cursor down to "IP Address". Press OK
(10) with the coursor select write the IP address among the margins of your Router. The Gateway numbers shlould be the same as the ip number of your router. MAsK is always 255.255.255.0
(11) press menu and restart the printer
IN YOUR MAC
(1)Install the 3110cn modules version 2.1.3 Build 5 (usually in the CD, or in DELL site download area)
(2) Open Setup Print Utility and select "Add a printer"
(3) Select IP printer (any of the possibilities you are offered are ok), WRITE THE ADDRESS YOU WROTE IN YOUR PRINTER
(4)In printing using select Dell
You can move the printer to wireless, just keep the IP address the same.
Hope this helps!
8/13/2019 10:47:00 AM • Dell 3110cn... • Answered on Aug 13, 2019
I have an error message
Here Are Some Points If You Follow, You'll Surely Get the Solution As You Know The error code mainly appears with an error message IOT Motor as when IOT Motor has failed, but the other causes may be include as Print Head Device (PHD), like PHD Unit incorrect seated, optional components, etc The prime way to fix the problem is to understand the reason first. To help you out in best possible way,you can also ask for approachable help from Dell Customer Support Services. Step 1:- Cycle Power on the Dell Printer §First, turn OFF your Dell printer. §Then wait for some time at least 15-20 seconds. §Next, turn the Dell printer ON. §Determine if the issue still occurs. If yes, then go to the next step. Don't Worry If You Get Stuck, I was Also Helpless But Got the solution From this trusted site. Kindly Visit: Fix Dell Printer Error 007-341 Toll-Free No: +1-888-633-7151
7/30/2019 7:56:42 AM • Dell 3110cn... • Answered on Jul 30, 2019
3answers
My Dell 3110 Colour Laser
There's not much on the web about this error message, but it does say to reseat the fuser. I found a writeup (with a picture) on how to do this.
http://en.community.dell.com/support-forums/peripherals/f/3528/p/19309114/19606748.aspx
Make sure that your printer is unplugged while you do this, also be aware that the fuser gets quite hot while it's printing and stays hot for a few minutes afterwards. Don't burn yourself! While the fuser is out you may want to blow out the dust from the printer with a can of compressed air.
If reseating the fuser doesn't get rid of the error message call Dell technical support at 1-877-293-1197.
Hope this helps
Please rate this solution, thanks!
7/16/2019 12:11:38 PM • Dell 3110cn... • Answered on Jul 16, 2019
2answers
My Dell Laser printer went offline and I cannot
My Dell Laser printer went offline and I cannot get back online
7/10/2019 8:39:18 AM • Dell 3110cn... • Answered on Jul 10, 2019
2answers
Dell 3110cn error 093-919 y cart
I don't have problems:))
9/9/2018 4:10:29 PM • Dell 3110cn... • Answered on Sep 09, 2018
My Dell 3110cn shows 003-343 restart printer - contact support - after I changed one color. What can I do?
Do what it says and contact Dell support.
12/27/2016 5:55:47 PM • Dell 3110cn... • Answered on Dec 27, 2016
2answers
Only cyan toner being used
6/26/2016 10:40:58 PM • Dell 3110cn... • Answered on Jun 26, 2016
Dell 3110 cn has full paper tray but keeps giving
The paper may not be 'lifting' as you push the paper tray in. Open the front 'door' of the printer, remove the toners, so that you get a clear view of the paper tray. Is the paper in contact with the pickup rollers ? The paper tray lift mechanism can wear and there is a small plastic component that can break. Replacing the paper tray will probably do the trick and fixe this.
11/24/2015 6:28:39 PM • Dell 3110cn... • Answered on Nov 24, 2015
My Dell 3110 driver won't give me the option to print double sided documents
Assuming your printer DOES HAVE a duplexer fitted, you need to use the option in the printer driver to 'get information from printer' - this will update the available options as far as the driver is concerned.
11/24/2015 6:23:32 PM • Dell 3110cn... • Answered on Nov 24, 2015
How configure duplexer dell 3110 cn
You don't really need to configure it as such. The printer should recognise the duplexer if it is fitted correctly, and it's difficult NOT TO. Printing a settings page will show the duplexer under Printer Options. You printer driver needs to be aware of the duplexer, there is an option to 'get information from printer' within the Windows driver. Once the driver knows the duplexer is available, you'll have an option in the printer driver to print double sided.
11/24/2015 6:15:51 PM • Dell 3110cn... • Answered on Nov 24, 2015
Printing with horizontal dark lines
Did the dark lines start after the change? If so, maybe the drum on one of the cartridges is damaged. (Since you mentioned dark, I'd suspect the black cartridge.) Try replacing cartridges. If that doesn't fix it, you can send it in for repair if it's under warranty. If it's outside warranty, I'd probably just replace it, unless you want to learn a lot about the innards of a laser printer.
5/4/2015 3:11:08 PM • Dell 3110cn... • Answered on May 04, 2015
How to sort a Belt drive close to life message?
This message starts to appear when the transfer belt has reached a pagecount of around 80,000 pages. The 'rated life' of the transfer belt is 100,000 pages, so it depends on how much you print as to when you will need a replacement transfer belt. Still widely available, and really easy to fit ( it's a user replaceable part - no tools required, and the instructions are in the user manual).
5/1/2015 9:25:46 PM • Dell 3110cn... • Answered on May 01, 2015
What is Toner Dispenser CRUM
It's (part of) the code on the toner cartridge chip.
5/1/2015 9:20:03 PM • Dell 3110cn... • Answered on May 01, 2015
How do i clean or repair a duplexer on Dell 3110cn printer?
Are there rubber rollers on the duplicator. They may need to be replaced or cleaned. Try using cleaning alcohol on the rubber rollers.
5/1/2015 9:07:59 PM • Dell 3110cn... • Answered on May 01, 2015
The printer is saying check Y cart 093 919. What is that?
The yellow cartridge is empty, loose or failed.
5/1/2015 1:36:49 PM • Dell 3110cn... • Answered on May 01, 2015
Dell 3110cn Laser Printer Logo
334 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
make reset factory dell 3110
  • Office Equipment & Supplies
