20 Most Recent Epson Stylus CX6000 All-In-One InkJet Printer Questions & Answers
2answers
Printing in blue only
try this:
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
11/6/2021 7:52:31 PM • Epson Stylus ... • Answered on Nov 06, 2021
Epson CX6000 scanner doesn't work after installing latest Vista service pack
Suggest you go to System Restore and roll back to a prior date. That will "undo" your update, but will not change any of your files (Word, Excel, Email, PDF, etc.) Click the "Start" and then type System Restore in the search box.
2/2/2018 9:29:55 PM • Epson Stylus ... • Answered on Feb 02, 2018
Print on negative
Aperture was set to 'black and white', the printer dialogue was usign colorsync to enforce a paper profile generated by i1profiler an and i1io (or an epson profile). when i set aperture's rendering brick to do it all 'in the printer' it's fine.
2/19/2014 10:54:47 PM • Epson Stylus ... • Answered on Feb 19, 2014
0answers
Down load driver
11/10/2013 5:03:00 PM • Epson Stylus ... • Answered on Nov 10, 2013
El problema que tengo con
mi imultifuncional marca eeror 90 como se lo quito o que tiene_
2/15/2013 12:06:28 AM • Epson Stylus ... • Answered on Feb 15, 2013
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
377 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
epson t30 2 red
  • Office Equipment & Supplies
