20 Most Recent Canon PIXMA MP495 InkJet Printer Questions & Answers
Mp495 Pulling one side before the other causing it to jam
The roller maybe sticky and cause the paper not to feed evenly. Clean the rollers with methylated spirits.
12/1/2021 12:58:37 PM • Canon PIXMA... • Answered on Dec 01, 2021
Canon pixma mp495 paper won' feed
Paper may be trapped (paper jam).
12/1/2021 12:49:15 PM • Canon PIXMA... • Answered on Dec 01, 2021
Why won't my canon mp495 scan photo's to
are you using the software that came with your canon?
if so you need to save them manually or you are not knowing where exactly it is saving them
12/1/2021 12:06:32 PM • Canon PIXMA... • Answered on Dec 01, 2021
My canon mp495 printer wont function
it needs a reset. u need to to service mode to do it.
11/7/2021 5:01:16 PM • Canon PIXMA... • Answered on Nov 07, 2021
Mp495 P03
Look in the instructions to find out what the button press sequence is to reset the printer.
11/7/2021 5:00:15 PM • Canon PIXMA... • Answered on Nov 07, 2021
CANON MP495 INK LIGHTS FLASHING
Hello, Try to press and hold the resume button (the triangle in a circle button) for about 5 seconds. In this way the ink level monitor is disable. Only if you put a new cartridge the ink level will be enabled. Regards !
11/7/2021 4:53:08 PM • Canon PIXMA... • Answered on Nov 07, 2021
My canon pixma mp495 has
Press Stop/Reset button for five second. After all your printer will start working.... thanks....
11/7/2021 4:43:20 PM • Canon PIXMA... • Answered on Nov 07, 2021
My Canon Pixma MP495 series says paper jam but there is no jam!
Hi. In the paper path is a plastic flag sensor . That detect theif there is paper or not . Maybe there is something activating it may it can be a small piece of paper or a foreign object. That sensor is located in the back side of the rollers
11/7/2021 4:42:35 PM • Canon PIXMA... • Answered on Nov 07, 2021
2answers
Why does all-in-one printer Canon MP495 keep showing up as 'offline' when all connections and cables are secure and PC can see printer?
canon mp495 printer offline error.pdf - WordPress.com
https://tumulcozi.files.wordpress.com/.../canon-mp495-printer-offline-err... the printer model to remove and select 'MP If an error message appears or if you ...computer keeps saying mu wireless canon printer is off line If you feel any of ...
11/7/2021 4:39:24 PM • Canon PIXMA... • Answered on Nov 07, 2021
3answers
Canon pixma mp499 is offline how do I fix it?
Make sure that it's powered on. If it is, then it sounds like it's not on your network. Run the setup program and enter your wifi network information into it, so that it gets on your network. If you've already done that, try power cycling the printer. I have to do that with my HP wifi printer every once in a while. When it goes to sleep it drops the connection.
11/7/2021 4:38:22 PM • Canon PIXMA... • Answered on Nov 07, 2021
3answers
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low. A C LED light denotes that the colour ink cartridge is running low. If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code. Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem. The led screen on the printer will flash a letter E and will then be followed by two numbers: Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
11/7/2021 4:28:14 PM • Canon PIXMA... • Answered on Nov 07, 2021
4answers
Error code E31 scanning with Canon MP495
Okay I found the solution. Spent two days solving it so actually the advertisment is a lie. Wireless he can only print but not scan. I had to plug in my usb cable to be able to scan. Hope this helped you. There's no way you can scan wireless.
7/22/2021 3:42:33 AM • Canon PIXMA... • Answered on Jul 22, 2021
3answers
Canon PIXMA MP495 InkJet Printer - Offline issues
For Vista wireless setup: Open your Control Panel. Choose Printers. In the Printers box it lists your printers. Hover over the wireless printer icon, right click, choose Run as Administrator, then choose Use Printer online. This should change the status of the printer to Ready (from Offline). Be sure you've chosen this printer as your default printer. Might have to do this on a regular basis.
10/25/2019 5:45:40 AM • Canon PIXMA... • Answered on Oct 25, 2019
I get error E31 message whenever I try to print
troubleshoot the printer from the printer
4/25/2019 9:41:51 AM • Canon PIXMA... • Answered on Apr 25, 2019
Mp495 scan without cartridge
It's a funny thing but, after trying everything above, I just pressed the SCAN button on the printer, instead of trying to do it from a program in the computer. It scanned the document and launched MP Navigator!
8/3/2018 10:58:17 AM • Canon PIXMA... • Answered on Aug 03, 2018
How do I find ip address for canon pixma mp 495 printer?
To print the LAN settings, press the Maintenance catch on the printer over and over unti you see a n on the LED, then press the Black or Color catch. When it prints out, let us know whether the association is Active or Inactive. On the off chance that it is Active, please let us comprehend what it appears for the IP Address and Default Gateway. If you want to get proper detailed information then 'you should call on 1-888-924-2961 toll free number anytime for canon printer support service. Technical Support For Canon Printer
2/22/2018 4:50:09 AM • Canon PIXMA... • Answered on Feb 22, 2018
Our canon mp 495 keeps showing a 1003 error - yet there is no paper in the machine to jam
try turning off the power switch.. unplugging then repulsing in. then turning power switch back on in that order,
1/5/2018 12:00:18 PM • Canon PIXMA... • Answered on Jan 05, 2018
Scanner not responding. Ink empty?
5/28/2016 6:49:29 PM • Canon PIXMA... • Answered on May 28, 2016
Canon PIXMA MP495 InkJet Printer Logo
443 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
step step instructions scan documents pc
  • Office Equipment & Supplies
