20 Most Recent Canon PIXMA iP4000 InkJet Photo Printer Questions & Answers
Hello my name Danny I am going help you on this matter If you go on this site and you can download drivers for your printer PIXMA IP  4000
http://download.cnet.com/BJ-Printer-Driver-Canon-Pixma-iP4000/3000-2116_4-10555918.html
Canon PIXMA... | Answered on Feb 16, 2018
It sounds like there is a blockage or junk sitting over one or more jets in the printhead.
https://www.youtube.com/watch?v=pEkKGBUSwNg
have a look at this u tube video and you may be able to fix it.
Canon PIXMA... | Answered on Feb 13, 2018
I solved this problem by putting a shim between the door & switch lever.
The shim is just a piece of cardboard/plastic/whatever about the thickness of a credit card & about 1/4 inch wide.
At the lower right corner of the paper outlet is an opening about 1/4 inch square. On the right side deep in this opening is a lever (rather hard to see). When the door is opened it lifts the lever up (presumably telling the printer the door is open). I took a small screwdriver, inserted it into the left side of the opening, turned it counterclockwise until it caught the edge of the lever & lifted it up, inserted the shim below the lever, & withdrew the screwdriver. This solved the problem (it has only recurred once since the shim was put in).
If the shim falls out just reinsert it. Of course, if you ever want to close the door you need to remove the shim first.
Canon PIXMA... | Answered on Dec 28, 2016
Print a test pattern print first to make sure that the problems is the printer and not the file you are trying to print , then check you color cartridge if it's empty.
Canon PIXMA... | Answered on May 12, 2015
You can't. You will need to replace the waste ink tank when it becomes full before it will allow you to print anymore. I had to do that with my Canon at one time too.
Canon PIXMA... | Answered on Aug 20, 2014
Go to the maintenance tab in the Windows Printer Driver property
Canon PIXMA... | Answered on Jul 26, 2014
If you have clean the print head several times,the problem is the prin head,you need to replace.
Canon PIXMA... | Answered on Jul 09, 2014
Canon PIXMA iP4000 InkJet Photo Printer Logo
597 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
paper output tray open but message says
  • Office Equipment & Supplies
