you do not need a CD to connect to the printer, what you should do is gain access to the print server. this can be done by asking your network administrator. in a situation where you don't have one or the network is an open one, you have to connect to the printer network, open your ipv4 properties and select obtain an ip address automatically, do the same with the DNS server and you're good to go.
just so i'm thorough, after connecting to the print server / network, you can access your network ipv4 properties by right-clicking on the network icon located at the lower right corner of your taskbar, (the bar at the bottom of your screen) usually in form of two computer monitors. select network and sharing center after right-clicking. a list of wireless network should be available if there are more than one wireless networks in the area. select view status of the print server / network, click on properties, a pop-up box appears. be sure 'file and printer sharing for microsoft network' is checked, double-click "internet protocol v4 (ip/tcpv4)' select obtain an ip address automatically, select the same for the dns server below. click OK you're good to go.
note
once you are successfully connected to the print server, click on Devices and Printers from the start menu, select the printer and allow the drivers to be installed from the server. once that is done, you can right-click on the printer and select set as default. after this all you have to do is connect and print whenever you want to.
hope this helps
let me know if there's anything you don't understand or if this doesn't resolve it.
